Front brakes acting bizarre after bleed.
Discussion in 'Maintenance/Repair' started by seaduck, Mar 7, 2013.
  1. seaduck
    seaduck Newbie
    NW Chicago suburbs
    1989 xcab extended 3vze
    Hi, sorry for my first post to be a problem.
    I've got an '89 2WD/3VZ-E/5-speed/xcab/long bed. The brake line running along the axle sprung a leak a while ago so I spliced in some fresh line with pressure fittings, as one does, and bled the whole system. Ended up going through 4 quarts of fluid before the air was completely gone and the truck would stop instantly. But over the next few days I would increasingly get occaisons where the pedal would go to the floor and only engage the rear drums. And that's gotten more frequent over the month to the point where I have no front braking at all. There's no leaks and no drop in fluid levels in the reservoir, and I can still get full response from the front brakes if I jam on the pedal while running around 50mph in 5th gear. Otherwise nothing.
    It's not fun running around with only rear brakes in this truck. Help please?
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    I have had brake fluid leak through my booster and it got sent into the intake and burnt white smoke out the back.just che if there is air in the line.If the pedal is going to the floor there has to be some air in there.
  3. 22r
    22r Veteran
    Maui
    could be the brake master cylinder. bleeding an old master cylinder can actually damage all the rubber seals on the piston.
  4. seaduck
    seaduck Newbie
    NW Chicago suburbs
    ^winner^
    Put a rebuilt MC on it saturday and it works perfectly!
    Thanks!
  5. 22r
    22r Veteran
    Maui
    glad to know your truck stops now! hahaha
  6. drrm123
    drrm123 Newbie
    Glad to hear you got it fixed.
