Turbo?!?!!
Discussion in 'Engine/Drivetrain' started by Live42day90, Jan 26, 2013.
  1. Live42day90
    Live42day90 Enthusiast
    Long Beach
    1995 Pickup
    I just recently have to replace my 22re engine on my 95 toyota pickup. i want to put in a stock one BUT i want to throw on a turbo kit. what are your guys suggestions? and if good, where could i get a kit for a decent price? thanks a lot
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    If U can source a decent manifold you can pretty much build a decent turbo kit around that if you have access or skillz to make a down pipe and other hot/cold side piping
  3. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    stock+turbo=boom. Just sayin. The ECU, AFM, and injectors can't do a whole lot more than stock. You could do it, but for any appreciable power gains will need a lot more than just the turbo.
    As the saying goes: speed costs money, how fast do you want to go?
  4. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    ^ na ya can do it
    but you are boost limted and have to run higher grade gas
    you can do ct26 with a fule regulator but stock boost as high as ya wana go
  5. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    How readily available are/were the 22rte motors? Are they worth the trouble as far as swaps?
  6. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    what are you going to do for smog testing?
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Agree a 22r or e can be turbo charged just can't go boost crazy there's plenty of running examples of dependable low boost motors
  8. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    it's totally possible, but this thread might give you some insights: 22RE vs 22RTE...differences - YotaTech Forums
    And what you'd put into a turbo setup could be put into the engine itself from the get go and get you returns across a larger section of the powerband, much greater reliability, and/or less hair-tearing-out.
    Just adding an engnbldr head and cam (about $600 for the combo, roughly), puts your engine at roughly the power range that the stock 22ret had.
    How much are you planning to spend on "a good stock one" for the engine?
  9. Turbo86
    Turbo86 Newbie
    Denver
    86 single cab sr5
  10. TRfknD
    TRfknD Veteran
    96 Taco / 05 Tundra
    If u want to keep it a toyota and 4 cyl...I recommend a 2rz boosted. A stock block on 15 psi can give u 300hp +. :D
  11. IronNam
    standalone, turbo setup, injectors to run safely and smooth.
    and build your bottom end if you want to run it hard, forever.
  12. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    Definitely a good bottom end speaking from experience if your not a peddle junkie stock bottom end will hold up for atwo or three years but if your in love with the sound of your truck spooled up and rippin then build you a solid long block with quality internals
  13. raylcc
    raylcc Addict
    Denver, CO
    I agree with above. Go with a good bottom end build from there. And by bottom end, think female gymnast, not Kardashian. Toned, tight and muscular over heavy, lumpy and dumpy. The extra investment now will pay off in the long run.
