the dropshop chop
Discussion in '1989-1995 Build-Up/Project Threads' started by mr.potatohead, Nov 3, 2012.
  1. mr.potatohead
    mr.potatohead Newbie
    NE wisconsin
    90 toyota pickup
    This is my first toyota pickup and after this blessing, it wont be my last!
    the day i got it. Paid $1300 for it with a leaky radiator and that was it. 163k on it.
    after a little work. topper and hub caps gone, and a quick rattle can coat of black on the wheels.
    picked up some 17" wheels for now and installed a DJM 3/4 kit and also gave it a BJ flip.
    it was riding on the bump stops after the drop, so i decided to make a home brew c-notch for the frame. Figured I'd give it plenty of room for future lowerings. 6" should be enough right?:waytogo:
    Ill be adding the bump stops and junk once it all completed and undercoated.
    Oh. and heres my other obsession. A ground-up custom built honda ruckus. Slammed and stretched to the max.
    Ill update as things progress.
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    nice truck bro.Attack that chasis before it gets bad.Love the Honda. looks like fun and nice wagon trailer too.
  3. 85Toyota
    85Toyota Addict
    ~Arkansas~
    '85 Toyota 22R s-cab
    Welcome to TM ... Nice toys, bro ... Keep the picz comin' ... :cool:
  4. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    Nice bruddah.. keep it going
  5. 77mini
    77mini Enthusiast
    That wagon is awesome. I want one lol
  6. mr.potatohead
    NE wisconsin
    90 toyota pickup
    finished welding the notches in, eliminated the LSPV, and sprayed the undercoating. Once the Undercoating is dry Ill finish installing the airbag shocks and trim out the box for fitment.
    there should be PLENTY of room for 3" more drop come spring.:evil:
  7. Malessohomegrown
    Malesso,Guam
    Came out nice man.
  8. mr.potatohead
    NE wisconsin
    90 toyota pickup
    thanks man! Got it on the road last night. Couldnt get the box trimmed up and installed because I didnt have an extra person to help position the box and set it on the frame. SO i rigged up the lights and plate so I had a vehicle to get to work and school. Its fun as hell to slide around corners and do burnouts without the weight of the box back there tho!:headbang:
  9. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    Red interior!....NICE!
  10. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Looking good!
  11. Bradthreee
    Bradthreee Enthusiast
    Palmdale, Ca
    1990 xcab
  12. Chikn Hawk
    Chikn Hawk Member
    671 Guahan
    94' X-Cab Toy Lux
    The display of piks are detail and helps to see how well u thought this out. Good job! One day I'll do the same. Whats ur C-notch specs if u dont mind?
  13. mr.potatohead
    NE wisconsin
    90 toyota pickup
    30* angled legs, 6" total notch, made from 1/8x4 and 1/8x3 flat steel.
    I figured out the height i needed and welded it all up to teh point I could slide the notches over the cleaned up frame, welded them in, then cut the frame out so it was always supported. then capped all open areas off and welded the rest of it solid. made the entire notch for about $35+time. :headbang:
  14. mr.potatohead
    NE wisconsin
    90 toyota pickup
    So Ive picked up a set of used belltech drop spindles. Plan is spindles with the arms, torsion down another inch, relocate shackles into frame.
    Then Ill be running 16x9 4.25BS spun steelies up front and 16x10 4.25BS in the rear. I know I will have to do some good fender pulling/ rolling. Not afraid. Hope it turns out!:doah:
  15. Beefed Taco
    Beefed Taco Addict
    Why the huge step notches if you're staying static?
  16. DannyBoy
    DannyBoy Enthusiast
    Tacoma, WA
    91 xcab
    keeps the bed from smacking the axle when taking bumps. gives your suspension in the rear end more the 1/2" of play lol
  17. mr.potatohead
    NE wisconsin
    90 toyota pickup
    Because once I am fully dropped, I still plan on using the truck as a functioning pickup, including using oem style bumpstops. On top of that, this was the first notch I had ever done and the first minitruck I have ever had. So I wanted to give myself PLENTY of room to do whatever I wanted to it without having to go back and redo work.
  18. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Big notch nuttin wrong with that could always add a load helper bags in there help with hauling 2 motorcycles wich could easily exceed 500 pounds
  19. mr.potatohead
    NE wisconsin
    90 toyota pickup
    I have the gas adjustable shocks from Gabriel already. I just need to install the selonoids and pump. Got one out of a new crashed linkoln for a steal ($40):headbang:
