speaker mounting?
Discussion in 'Interior/Electronics' started by brand0n327, Jun 25, 2010.
  1. brand0n327
    brand0n327 Member
    indianapolis
    1987 toyota pickup
    i want to buy some nice speakers for my truck...but there is only 2 mounting spots and they look like they are about 3 inches...i cant find any speakers that small...any help would be great
  2. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    I would make speaker pods for your doors.
  3. jetas
    They should be 4" speakers
    Make speaker pods or atleast some 2-3" risers and mount them in the doors
  4. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Cut holes in the door then make some speaker pods. If not make some in the kicks. That would sound wayyy better then the ones in the stock spot.
  5. thundering02
    thundering02 Addict
    Fenton 63026
    Mine in the dash were 4 or 4.5 inch. I had two 6x9s in boxes from walmart behind the seat that were fantasic. Otherwise youre cutting holes in say the doors.
  6. Grizz806
    Grizz806 Member
    Boondocks,Lubbock, Tx
    1987 2wd
    I have 8 total two in the dash, two in the kicks, two in the little slit of door right under the seat belt thingy, and two shallow subs behind the seats.
  7. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    The oem location speaker in the dash are 4" but because they only have 2 screw holes, manufactures at one time made a special 4" speaker called a 4T (T for Toyota), it was basically the same speaker with different mounting holes, although i have placed regulare 4" speakers as well as crammed 4x6's in these locations before. Sound quality is crappy because the speakers fire toward the seat and not towards the passengers ears. In my 86 yota i removed the plastic factory kick panels, modified them, built them up with mdf and wrapped them, so that they housed a set of 5.25" crossfire bmf components, way way way better sound than having just the 4" speakers.
  8. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    i wouldnt want to make holes on my door panels.
    esspecially if they where in good condition to.
    i would make speaker pods for the kick panel instead.
  9. brand0n327
    brand0n327 Member
    indianapolis
    1987 toyota pickup
    where are the kick plates?
  10. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    The kick pods are the plastic pieces that are in the floorboard, but on the side walls, ie. under the dash, down and to the right of the glove box, then symetrically on the opposing side of the vechicle, you have to be conscious of placing speakers there, or else they will get damaged.
  11. broke-ass-yota
    broke-ass-yota Member
    Florida!
    87 pickup
    yo you got pics of that setup?
  12. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    Kick pod/panel
    WAT YEAR IS YOUR YOTA?IF IT'S A 70-83 YOUR GONNA NEED TO MAKE A KICK POD/PANEL,IF IT'S FROM A 84-UP THERE THE LIL PLASTIK PANELS THAT A THERE UNDER THE DASH. A PICK OF A KICK POD/PANEL WITH SUM SPEAKERZ THAT I HAVE ON MY 94 RUNNER.THIS IS WAT IT LOOKS LIKE BUT MINZ GREY.
    HOPE THIS HELP'S?:waytogo:
  13. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    nice kicks but my ears hurt now.. :(
  14. planemos
    planemos Toyotaholic
    British Columbia
    Yea nice but where would u put your feet if you had firewall tubs too.:shrug:
    It's good to see that the tweeter is next to the speaker. I don't think it is good for the tweeter to be mounted more than a couple inches away.
    So is this an extra cab we are talking about? b/c I had some JBL GTO series 10inch subs and they worked in my 88 extra cab. I made these boxes that were fully enclosed (no ports). I looked on the specs and they were the smallest I could make them. I think they were about 1ftx1ftx1ft box. I mounted them in the back on an angle facing forward and they actually fit perfect. And boy did it ever sound loud and bass-eeee.
    And inside the box I had to shred up some cloth strips according to specs.
  15. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    yea components are best to be on the same plane for imaging, and man i'm surprised you had a box that measured 1x1x1 and it sounded good, usually a perfectly cubed box is not good acoustically for subwoofer dynamics.
  16. yota4life
    I have a set of 4" in stock spot an a set of 6.5" in the door. Sounds good an is pretty loud.
  17. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    yea if you ever want to, since the stock oem toyota 4T speakers are free-air, you can pull the covers and shove 4x6's in the grill and they hold snug and play free-air also, although it angles the speakers downwards which is unfavorable. When i get alot further on my truck, i plan to build an entire fiberglass dash, i am aiming for atleast 3-4 pair of components in the yota, one or two pair being molded into the top of the dash, possible a pair or two in the doors, i figure since imaging is not very easy in our truck i may as well flood the cab, ha.
  18. slammedyoda85
    slammedyoda85 Newbie
    CA
    1985 Standard cab pickup
    Speakers
    If you have not found a place for them. i have bomber seats in my 85 single cab witha custom box i built with four 6 1/2 kicker speakers and two 10 inch kicker subs. along with kicker 3 1/2 inch speakers in the dash and they also make kick panels that im going to purchase to put 2 more kicker 6 1/2 speakers. a good place to buy that stuff is on sonicelectronix.com. if i were you i would not cut holes in the door.
