1991 toyota pick up lowering kit
Discussion in 'Suspension/Chassis' started by Relyks13, Nov 27, 2012.
  1. Relyks13
    Relyks13 Newbie
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    The second choice is the ideal one but all you will need for a basic drop would be drop blocks,u bolts and tortion bar adjustments.
  3. Relyks13
    Relyks13 Newbie
    but how low will that be from the ground on 17in rim i never can find any pics to compare
  4. Micro Machines
    Micro Machines Member
    Portland OR
    92 xcab 22re
    I have done this basic drop lots of times on my trucks and with 17in rims you can pretty much lower it enough to cover the top of your tread in the front. As for the rear, it all depends on how big your drop blocks are. The bigger the block, the lower the drop! This can be done for about $60. The cons for adjust torsion bars are alignments and uneven wear on your front tires.
  5. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    As long as you get the truck aligned after you drop it, you really shouldn't have to worry about the uneven tire wear especially considering the fact that your drop would be static and not adjustable. The alignment will probably be the most expensive part of the drop. But hey, tires cost a hell of a lot more than an alignment, right?
  6. Relyks13
    Relyks13 Newbie
    hmmm what about shocks leafs and spindles ?
  7. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    spindles are really good i think its the best drop ride your going to get..and if u get good drop shock it would make it ride solid...drop leaf r good to...i have the same set up and my mini rides like stock hight...
  8. planemos
    planemos Toyotaholic
    British Columbia
    The front leaf spring hanger will be the lowest part when you drop it. I remember when I was static dropped those hangers would scrape on everything. I had de arched leaf springs and 3 inch blocks.
    The secret shock to use is a 69 Camaro front shock from a 302 V8 Camaro. They require very minimal modification to get them to work (enlarge the lower mounting holes). But I believe they are a tad shorter so you need to adjust torsion bars. They totally work awesome. I used KYB Gas a Just shocks. Then I just got stock KYB Gas a Just shocks for my model truck for the rear. I think the KYB would be cheaper than the Nitro Drop shocks and work just as well.
    17inch rims are bigger than stock so it would be giving you more clearance, allowing you to do a suspension drop with less clearance issues.
    Spindles are very good because they maintain the correct suspension geometry but still lower the vehicle and keep a comfortable ride. And when messing with the rear axle you need to make sure the driveshaft angles (between tail of transmission and front of pinion) remain correct.
  9. Relyks13
    Relyks13 Newbie
    anyone got any pics of what this drop should look like or what i should expect :)
  10. blue_toy93
    blue_toy93 Newbie
  11. blue_toy93
    blue_toy93 Newbie
    Try that *
  12. Relyks13
    Relyks13 Newbie
  13. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    That is a great setup. That price is a steal too. If you have the money I would grab that while at that price.
  14. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    DJM is one of the best suspension kits out there. Ive been using them since the early 90s.
  15. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    thats a solid set up...i wish i had this kine of price when i dropped my mini...
  16. jtlrider
    jtlrider Newbie
    Do i need shocks with the djm suspension kit ?
    Forgive me I am new to this forum as well as forums in general. stupid question Im thinking of lowering my 93 toyota as well. this DJM suspension kit which includes control arms and rear blocks.. Do i need to buy shocks as well. or will my stock shocks still work if i order this DJM kit. thanks and are lower control arms better then spindles as far handling or vis versa. ? thanks
  17. Da_Roach
    NOVA
    Now would be a good time to buy and replace your shocks, if you do reasearch you will find the correct shocks. I use kyb brand and love them.
  18. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    You still need the DJM lowers, for alignment specs.
