Steelies
Discussion in 'Wheels/Tires' started by jaybee, Jan 10, 2013.
  1. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
  2. MilehighHilux
    MilehighHilux Enthusiast
    Might have to do a fender roll and pull. I'm doing 15x8 +25 here in the next month or so
  3. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    so u think runing 15x7 would be better
  4. MilehighHilux
    Won't be that much work. I honestly don't think you will need a pull. But I've seen 16x8 and lower offset (spacers) with not that much fender work . So your best bet will be to just try it and see if you like it or not and how much fender work you want to do honestly
  5. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    i think 15x8's should work well with a different offset. plus it depends what year he gets because i think older bodystyles are a lil narrower. my 15x8's rub my back fenders all the time and i'm only at a 4inch drop.
  6. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    my 15x8's dont rub at all in the rear with my 4 inch drop, but my wheels are 20mm offset in the rear with a 195/50 tire. if i put a spacer and make then to 15 or 10mm offset then i can see them kissing the fender easily. upfront i have a big enough spacer to run the wheel at about -16mm with the same size tire and no rubbing yet.
  7. Madness
    Madness Enthusiast
    Westminster, Co
    4-4 drop, 15x8, et0, 185/55/15
    Front rubs the inner fender skirts while turning and going through a dip or over a bump.
    The bump stops in the rear are cut in half. The axle hits the frame before the tires rub.
    Crossmember hits the ground all the time.
  8. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    oh that's cool... i run the same size tires but i guess the offset on my rims are a lil more out there. :cool: maybe i should try some 185/55 when my tires get bald again.
  9. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Yea that's what I was thinking, your offset is lower and it could be the brand of tire as some companies are a tad bigger/smaller then others.
  10. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
  11. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    going with a 6/6 drop you may want to run a 50 series sidewall on that tire. 60 will be too tall and definitely will rub.
  12. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    this my truck 15x8 w 0 offset with 185-60-15 w a roll fender and i never rub...and this was a 7-6 dropped..4" block and 3 inch lowering and spindal in th front w a BJ flip...:D
      File size:
      44.9 KB
      149
  13. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    Backed oredered this Steelies from a local 4 wheel shop. What do u guys think. O and its 15x7 with 0 offset.
  14. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Not too bad
  15. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    Jaybee if those new wheels workout hit me up for your current wheels would look sick on my tacoma..
  16. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    I think these are going on his brothers truck.
  17. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    iThink those beadlocks would look sick on lowpros:cool: they might be a lil heavier than aluminum rims but its worth it. i don't think many people run beadlock looking rims on dropped trucks
  18. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    thanks my bruddahs...wondering if anyone has a pic of this rims on a mini
