Toyota engines and Standalone ECU's?
Discussion in 'Off Topic' started by Beard, Jan 13, 2013.
  1. Beard
    Beard Member
    What standalone fuel management systems are commonly used with Toyota engines? Are there any that are better suited for use with Yota's or just get one and go?
    Currently I am working on installing a 1994 1UZ FE out of a LS400 into my 1994 Toyota Pickup. I do not want to retain OEM ecu because I am using the OBX ITB's and I would also like to convert it to coil on plug since I have a ton of coils already from building motorcycles (including harnesses).
    So far, the best option I have found that suits what I need is the F.A.S.T. XFI with dual wideband. It has seven inputs and outputs so I can work dash functions and stuff. It is a really nice unit, but I want to make sure it is the best option.
    Would I be fine with the XFI or what would you go with?
    I will be using the Quantum-Auto manual conversion kit, so no automatic trans will be used with the setup either.
  2. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    There's always megasquirt. Can be made to fit any engine, ignition system, or fuel system. It's like linux though, you kind of have to know what you're doing and want to work on it. It's nowhere near typing lines of code, but EVERYTHING is adjustable and has to be adjusted.
    I've had one sitting on the shelf entirely too long (got it, then moved into an apt for school, then into a house with no garage/small driveway, etc)
  3. Beard
    Beard Member
    I have used Megasquirt in the past on some Honda builds and honestly, I don't like it. It is not finished or refined. It has absolutely no user interface and cannot do a lot of automated functions that developed standalone systems do.
    It may be a cheap option, but the headache it gives you for the money savings just isn't worth it to me.
    Especially when trying to tune an ITB'd engine.
  4. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    I had a girlfriend in high school nicknamed "Megasquirt"...carry on.
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Hahahahaha . That's all I needed .
  6. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    really at this point when it comes to stand alones theres tones
    the new mega squirt 3 is pretty good for cheep scale and next is micro tec lt16 then spart spending and get a hall tec motec ect
  7. Litneon
    MSII is great too. Not sure why it wouldn't be as refined as other stand alone systems. It has all the same options as anything else I've looked at if not more. And the price is half of the next company's.
  8. IronNam
    Isn't MS much more expandable?
    and I heard OBX ITB's aren't the greatest via Lexus V8 forums.
  9. NashMan
    NashMan Toyotaholic
    94 2wd
    it just not as jam packed with stuff like the newer stuff
    you can not run coil on plug it does not have eghough channles
    and would have to run batch fire
    the newest mega quirt has alot of new things added and it does look go for it's price
    and has a nice huge list of options now
    and it's getting better and better as time moves on
  10. TRfknD
    TRfknD Veteran
    96 Taco / 05 Tundra
    I love my MS II and it has all the options I need and I'm at 415hp to the wheels @ 17psi! Nuff said!!!:cool:
  11. '80yota
    '80yota Enthusiast
    Spokane, WA
    '80 Sr5 Long bed
    Im a huge fan of megasquirt. Got a DIYPNP kit from diyautotune.com for my mk2 supra when I had the stock 5mge-NA-t got it going and running great (had converted to coil on plugs, and a map based air intake sensor vs the stock door/flap style air flow meter).
    I will be reusing the ecu and just building a custom harness for my 2jz Swap into the same mk2.
    I have a good friend using ms3 in his 500+hp 7mgte swapped mk2 supra, he also has the megashift auto tranny control unit aswell.
  12. NashMan
    NashMan Toyotaholic
    94 2wd
    ^ for example m3 pro control's knock and has trac-control and bunch of other stuff i may convert my car over but we will see
  13. Litneon
    There is an add on card for MSII to control spark on each cylinder in a coil on plug setup, but it can run a waste spark setup which will work for most applications. MSIII has addressed this issue.
  14. Beard
    Beard Member
    I have read over what MS3 has and it still lacks in areas where I want it to perform. I am after a good user interface with wideband and logging. I need to be able to street tune often because I will be experimenting a lot with this engine and trying to work out an Idle Air Control system with the OBX ITB's.
    The main problem most people have the OBX units universally is idle issues and they are often not sync'd. A functioning IACV system and a good sync works wonders if you tune your engine using speed density.
  15. NashMan
    NashMan Toyotaholic
    94 2wd
    another cheep option and works very well doe snot have all the bling bling to it is the mirco tec efi
    only has one issue I do not like is the maps are stored in series to usb adptor
    I have no air valve in my car and no do alot of rx7's
    Microtech EFI
