And here.... we... go.
Discussion in '1989-1995 Build-Up/Project Threads' started by Litneon, Mar 26, 2010.
  1. lownloud
    lownloud Toyotaholic
    Plains, Montana
    So cool, awesome build. Me - I do enjoy the heck outta my reverse 4 link. . . Keep up the good work. . .
  2. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    killer build. I just read up on your build and really love your rear set up and door pods. Top notch!!!
  3. Litneon
    Thanks guys.
    Corey, start a build thread! We'd all like to see it.
  4. Litneon
    What's this? Full lock to lock steering and shocks on a bagged mini?
    Yup. ;)
  5. donellk
    donellk Member
    Palm Bay
    '93 Toyota Pick up
    How long are your front shocks?
  6. Litneon
    15 1/4" eye to eye extended with 5 3/8" travel.
    I retain full movement in every direction. They were best I could find...
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Any news on your build/turbo setup
  8. Litneon
    No real news. Work has picked up and I've been working crazy hours so I haven't had time.
  9. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    Can you post up pics of the bed area?
    Thanks
  10. tomato
    tomato Member
    palmyra, missouri
    92xcab-904x4-05taco-76fj40
    beautiful truck!:waytogo: on the subject of shocks speedway sell a "t-bucket" shock that has a reduced diameter body, although im not sure of extended/ collapsed length...
  11. Litneon
    Ok, finally working on fixing the broken FB pic links....
    Give me a few days, as I'm also working on the truck. I've done a lot over the last few months, just haven't had time to post them all up.
    Just a small preview....
    [​IMG][/URL][/IMG]
  12. Litneon
    Took my lunch today and fixed all of the broken links on the bed build. Didn't post as many pics this time, some of them were redundant.
  13. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    Motor looks good will the downpipe hit the booster I ask because it looks like it would
  14. Litneon
    HaHa! No. It is close though.
  15. burnzya
    looking really good.
  16. Litneon
    Ok, so... had to build a turbo manifold. Might as well go from scratch. Went a little heavy to eliminate any chance of cracks developing from the heat cycles.
    Had to machine a flange with the coped radius in it (rather than trying to blend some pipe).
  17. Litneon
    It won't be the most efficient manifold ever, but I don't think it'll be too bad.
  18. Litneon
    Engine work:
    Built short block. All forged internals.
    My boy Jacob helping out.
  19. Litneon
    Drilled the oil return port. I chose to put it above the factory location on the 22rte, but there is plenty of clearance inside the case.
    I tried using the Toyota VAST ignition with the MegaSquirt controller, but it was giving me headaches and I gave up on it. I ordered a missing tooth wheel and Hall effect sensor - vastly more precise timing.
    Also decided to shave the intake manifold as much as possible.
    Machined the trigger wheel to locate it behind the crank pulley, rather than the customary front mount. It allowed me to tuck the sensor further back out of the way, which is helpful with the three belts on our trucks.
  20. Litneon
    Did some mock up on the old motor to build my down pipe. I hope it looks up to par with some of the other choices I've made.
    Turbo in place.
    I marked it and taped it to keep from having to tack it at home. Took it to work and tacked it up.
    Not the best pic, but finish welded. Next I have to finish the rest of the stainless exhaust...
