Ideas on where can I put my Battery?
Discussion in 'Engine/Drivetrain' started by gilpet79, Nov 27, 2012.
  1. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    Okay since I have put the trailer fenders on my truck I want to try and keep everything real simple and clean under the hood. I also dont like the idea of it in the bed.
    My problem is I can't figure out where I can put my Battery? I have a Interstate Honda battery to go in which is wayyy smaller than the OEM. The battery is a 51R and is L9.5" x w5" x h9''
    Here is what im working with in the engine bay
    So any Ideas? any pics of your battery relocation?
  2. bmjwright
    bmjwright Newbie
  3. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    you can get a $10 battery box and mount it behind your seat to one corner.
  4. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    Not mine. Something like this but in a box.
  5. raylcc
    raylcc Addict
    Denver, CO
    How about under the truck where the spare tire would normally go? My first thought was hidden under the dash, behind the glove compartment door with the interior (pocket part) of the compartment taken out. Not sure there would be room though.
  6. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Here's what I did[​IMG][​IMG]I made it so i can padlock the hatch and it's also padlocked to the bed frame.
  7. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    1983 Toyota SR54x4 Mojave Edition-Black Package Shortbed Sport Truck
    bmjwright has the best solution. I have two of these on my Mercury Custom and one on my 32 Ford Coupe for years. They hold up really well and allow decent access to the battery.
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Under the bed mounted on a shelf cheap and easy to make if u can weld
  9. macawilial
    macawilial Veteran
    Born and raised in San Diego
    Odyssey Battery
    switch your battery out to a smaller one. Small enough to put behind your seat or even behind your glovebox
    Warning, They ARE PRICEY
  10. TRUCK ACTION
    I have a Odyssey PC1500 in a battery box from Summit,behind the drivers seat .With both positive & ground distribution boxes over it.
    Changing the hold downs right now so can remove the nuts from the top instead of the bottom.
    Also run all 00 cables to a main ground @ the frame & to another distribution box in the engine bay.:cool:
  11. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    Okay so it looks like the best option is to put it behind the drivers seat. Who uses that space anyway lol.
    My question now is since I dont have a "sealed" battery aka acid caps, Do I need to run a vent tube to the outside or can it just go in a box?
    TRUCK ACTION do you have a picture of your setup? I would really like to see how you did the distribution boxes.
  12. burnzya
    i'm doing front fenders on a club members frontier. he's running a kinetik battery that is supposed to be the same size as the honda batteries. i mounted right back where it would be stock, but kept it as low as possible to clear the lights and stay out of site.
  13. TRUCK ACTION
    Here's what I have ,one positive & one negative distribution box above the battery ( the positive one has a voltage read out), the other stuff is the air management ECU, & pump relays.Most of all in the cab is for stereo amps,pumps & air controller! The silver box in front of the battery box & on the side wall is the electric engine fan controller!
    The distribution box in the engine bay ( circled) gets a feed from to battery, & feeds all there,the main fuse panel @ the engine gets power from it & back into the cab through all the stock wiring!
    Built by me ,for me & driven hard!!:cool:
      File size:
      60.2 KB
      79
      File size:
      83 KB
      80
