Post your suspension set-up.
Discussion in 'Suspension/Chassis' started by 89-ED7, Oct 20, 2012.
  1. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    And a roadster mazda that makes the toyota look like a monster truck!!:ROFL:
  2. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    7-6 dropped...4" block w a 3" dropped leaf..front is spindal and BJ flip w a lil torsion..also had it notch from LOLUX...:D
      File size:
      55.3 KB
      310
      File size:
      47.4 KB
      308
  3. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    and whats the wheel and tire combo?
  4. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    I use 15 x 8 wrap w 185-60-15 all around..
  5. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Cranked torsions upfront, 4 inch beefed taco blocks in the rear. 15x8 with 195 tires.
  6. yota4life
    Haha ya thts my brothers old Mazda bodied to the pinch. For the yota being static haha not tht much of a monster truck. The yota ended up being traded for a bagged an bodied Mazda an the new owner of the yota ended up lifting it on bags an like 22s or something
  7. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    FRONT- 3INCH DJM LOWER CONTROL ARMS. 2INCH DROP SPINDALS. TOXIC SHOCKS. CRANKED TORSION UNTIL IT MATCHED THE BACK.
    BACK- 3INCH DR-ARCH LEAFS. 4INCH DROP BLOCKS. TOXIC SHOCKS.
    Supra likes this.
  8. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    your truck is a work of art man. no notch in the back? and whats the wheels and tire set-up?
  9. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    Bruddah... cherry looking minI..I like try go lower for my mini but to much scrape in the bumps..Bra..planning to put low pro's.. right now am wrap w 185-60-15..
  10. TRUCK ACTION
    That's why you go air---ride low ----lift when needed!!!:cool:
  11. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    oh yeah forgot i do have a mini c-notch. Wheels are 16x7 crown victorias on 205/40r16...
  12. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    thanks..i know how you feel i just know the routes on where to avoid the bumps or remeber where everything is. When i park, i park really far to avoid the bumps and it helps not getting door dings from other cars.
  13. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    new set up for now...
    Front-flipped ball joints (lower only), and 15 full cranks down on torsion bars
    Rear- 4 inch angled blocks
    Wheels-16x7 +18?, 16x8 -10 starions
    Tires-205 50 16 hankook
    Additional comments about the set-up- Bump stops in rear cut down half way and re-shaped to a point. Handles a 1,000 times better but bottoms out on bump stops on really hard bumps. Plan to add spacers on front wheels at some point to bring wheels out a bit further.
    Supra likes this.
  14. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Nice truck, is it a x-cab longbed??
  15. Beefed Taco
    Beefed Taco Addict
    STATIC DROP
    not dropped to the point I'm scraping everything
    rides & handles great
    TRUCK
    1999 Tacoma std cab
    DROP
    5/7
    FRONT
    b/j flip
    2" Belltech drop coils
    REAR
    4x4 leafs w/leaf removed
    Streetacos special 4" blocks T-OSP (tapered-offset pins)
    CHASSIS
    deep c-notch
    cross member notch
    SHOCKS
    KYB Monomax
    BED
    ridge above diff trimmed for clearance
    fender lips trimmed for tire clearance
    FRONT FENDERS
    4X4
  16. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    yeah, long bed 87.
    ps- make sure to post pics when you list your set-ups guys.
  17. minidzl
    minidzl Member
    Coeur d'alene ID
    static drop: lowered torsions, new frame from cab back, triangulated 4 link, with coil over shocks factory wheels and tires
    Bagged: replaced rear coil shocks with bags, i didnt make the notch tall enough so it doesnt drag frame in the rear its about 1 inch away with 205/40R17's front suspension is all stock except replaced torsions with bags. front tires hit inner fenders and engine cross member hits the ground
  18. Unfinished_business
    Unfinished_business Newbie
    20s and a 3.5" drop till i finish getting bag parts
