static drop..... how low are you?
Discussion in 'Suspension/Chassis' started by SD YOTA, Dec 25, 2008.
  1. SD YOTA
    im waiting on some parts to go just a bit lower than my current status but, who here is the lowest statically dropped truck? what do you have done or how did you do it?
    me, im currently at a 4/3 with 2" spindles up front, a B/J filp, and slightly eased down torsion, rear have belltech 3" leafs.
    to go lower im gonna be running a 205/50/16 setup on my starions, 3" lower control arms, and a 3 or 4 inch block in the rear. i may go lower yet and mill myself out a front lower balljoint spacer.... possibly 1" or 1 1/2" thick to bring it down more. :D
    here's what mine currently looks like.......
    ryans88yota likes this.
  2. Litneon
    Static 3/2 drop, spindles and lowering springs.
  3. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    here is a picture of my first '86. its got lowered torsions (sittin on the bump stops) with a 3" block on rear, the only other thing on the rear is the shocks, there load shocks from a 1st gen truck, if i remember correctly there like 1/2" shorter than the 2nd gen shocks. I will be droppin my turbo truck in the next 2 weeks!
    Paul Hosier likes this.
  4. SD YOTA
    litneon- what wheel/tire combo are you running?
  5. Litneon
    They are 225/40/18's on 18 x 7.5" in the front and 265/35/18's on 18 x 9.5" in the rear.
  6. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    what do you think of the lowering leafs vs. block lit
  7. SD YOTA
    honestly, for how much leafs cost vs. a block kit..... leafs hands down.
    the ride is sooooo much better. not to mention less axle wrap.
    i have the belltech 3" drop leafs by the way.
  8. Litneon
    Leafs all the way.
  9. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    But can the leafs carry a load of say 500-1k lbs?
  10. Litneon
    Yes, they are capable of carrying the same loads as the stock leafs.
    BTW half a ton is pushing it anyways, even on the stock springs.:eek:
  11. toy_boy
    toy_boy Addict
    California
    1979 Toyota 4x4
    I sat here debating this very same question for weeks; leafs vs. lowering blocks - over and over, again, in my head. If the ride is THAT much better than going with blocks, then leafs it is.
    Sometimes it's so tempting to go that less expensive route to get that instant gratification. :eek:
    But at the same time, I know in the long run it pays off to be patient and to do things properly. :)
    Just wanted to sound off - I really appreciate this thread - thanks guys.
  12. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    yes, i know that is alot of weight. but my turbo truck is what huals the bikes around. my harley is the heaviest at a dry weight of 545 lbs. and my buell is 395 lbs. so that is y i was wanting to know.i will most likely later on get lowered leafs, but for me, blocks work for now.
  13. SD YOTA
    my belltechs do not haandle weight well....:rolleyes:
    its a 2 leaf pack so ride is sacrificed over load capacity. mine will squat with around 300lbs back there...... they will likely bottom with more than 500lbs :D
  14. Rayvin
    Rayvin Member
    I have flatteren leaves (reset) with 2 1/2 inch blocks and major wound torsions (no rake) no bump stops in front or rear and tucks 17's with 40 profile tyres nicley.
    Dont get axel on frame bash even on potholes front will rub on the firewall if reversing down a hill (gutter) while at full lock
  15. SD YOTA
    nice, can we get a picture of your ride?
  16. SUNSETJOE
    SUNSETJOE Enthusiast
    San Diego
    81 SR5 longbed
    5" in the front and about 4 1/2" in the back...
    Neilson, twizted1 and Paul Hosier like this.
  17. Asha'man
    Asha'man Member
    Denver
    '85 Xtracab 2wd, '86 4Runner
    Sunset - nice ride! Are those 18s? How'd you lower it? I have an '85 Xtra cab as well, and am looking for ideas.
  18. SUNSETJOE
    San Diego
    81 SR5 longbed
    The wheels are indeed 18's! As for the drop... I loosened the torsion bars, cut off all of the bumpstops, cut and raised the front shock towers about 2 inches, 4" or 4 1/2" DJM pinion correcting lowering blocks on stock leaf springs, and cut out the front wheelwells!:waytogo:
  19. SUNSETJOE
    San Diego
    81 SR5 longbed
    Stock height...
  20. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Hey man the truck looks sweet! Question tho.... what rims are those from?
    Thx SS Joe!
