Starion Wheel Tire Sizes? PICS
Discussion in 'Wheels/Tires' started by 89-ED7, Oct 26, 2012.
  1. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    I've been looking through this whole forum at all the pics of Starion wheels and I'm having problems finding what tire size i want to order. Wandering if you guys can post pics of your Starions with tires and post the sizes. I really like the look of the tires on this truck someone posted a while back but don't know what size these are. I'm thinking of going with 205 50 or 205 45's.
  2. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    depends on how bad u want ur speedo to be off by im running 205-50 tires all arounds and my speedo is off by like 10 mph its my dAILY kinda annoying but totally looks nice imop
    [​IMG][​IMG]
    [​IMG] btw im running 16x7 starions all around
  3. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    i think you just made my mind up for me. i was leaning towards 205 50's more. i'm gonna order them now but everyone still feel free to post your pics...
  4. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    Just a ? but why does everyone run these rims w no center caps on in front? Is the bore not big enough or is the dust cap too big? Seems you could be able to beat the cap in to get a "finished" look here...
  5. NorCal Mini
    NorCal Mini Member
    Bay area CA
    1991 22R S-cab
    I have them on mine. Don't like the look without them
  6. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    because the clips on the 16x7 center caps hit the hubs on the truck. i'm gonna glue mine in and modify the clip to clear. i think the 16x8's clear ok but i'm not sure.
    i have 205 50 hankooks on the way...
  7. yotarip
    yotarip Veteran
    ^ nope. My 16x9's don't clear either so I'm sure the 8's don't.
  8. veedubfreak86
    veedubfreak86 Enthusiast
    PNW
    89 toyota ex-cab 2wd
    I have the 16x8 and 16x9 and I don't have any clearance issues with the caps
  9. yotarip
    yotarip Veteran
    Let me clarify. I am mostly sure that the 84-88 trucks have the issue.
  10. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    i have a full set of 16x8 and i have no clearance issues with the caps
  11. stock94
    stock94 Newbie
    Nice truck. What tire size and drop setup are you running?
  12. NorCal Mini
    NorCal Mini Member
    Bay area CA
    1991 22R S-cab
    Thanks man! Tires I'm running are 195/45/16 on 16X8 all the way around. My set up is a 4 on 4 drop with Belltech spindles and torsions cranked and 4" blocks in rear. I would love to go lower but it's a daily and I haul my other hobby which is collecting 80s arcade games you can kind of see some of my games in the garage from the picture.
  13. topcop182
    topcop182 Addict
    1993 single cab 2wd
    Dude! Must bow down for that one! I think I am going to run a little bigger tires and not so much of a drop.. but dang your truck looks perfect! :bow:
  14. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    i went with 205 50 16 hankooks all around.
  15. someday
    someday Member
    Santa Barbara, CA
    85 xtra cab
    same here. they work fine for me
  16. someday
    someday Member
    Santa Barbara, CA
    85 xtra cab
    I've got 16X8 up front (205/55r16) and 16X9 (225/50r16) in the rear.
    Front is 2" spindle and cranked torsion bars 2", and rear is 3" block. I had to bend the inside fender lip up on the rear tires for clearance, and the front rubs a little so I'll be going back up a little. I like the sidewall height, but need to stretch some tires so I can get the clearance up front.
    Here's my build with pics for reference
  17. Muttley81
    Muttley81 Newbie
    same here no issues 8's and 9's
  18. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    205/40/16
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
  19. standardbyker88
    I agree that a 205/50 is just right. I used to run them on some 16s I had. Perfect for the front. Out back a 225/50 is a bit meatier and gives a "big and little" look which I dig. A 55 is too tall, and a 40 will mess the gearing up too much. Not just that the speedo is off but 1st is useless and 5th is too short. I have that issue running 215/45/17s and 4.10s.
  20. 89blaster89
    89blaster89 Enthusiast
    western wa
    93 singlecab
    yea i want to get smaller tires for my starions so i can be lower... i have 55's
