MPG what are you getting?
Discussion in 'Engine/Drivetrain' started by Biggja22, Oct 22, 2012.
  1. Biggja22
    Biggja22 Newbie
    Twin Falls, ID
    Looking
    What are people getting and with what kind of set up? Engine, carb tires etc? My truck seems to be drinking gas like II drink beer
  2. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    I get 24MPG average w Weber 32/36 and 15 rim w 185-60-15..
  3. ryans88yota
    ryans88yota Enthusiast
    olympia wa
    88 2wd base reg cab.
    Bone stock 22r freshly tuned with factory 14s 195/75/14's I'm gettin 28 4-speed Manuel.
    When was ur last tune up? Carbed or FI?
  4. TRUCK ACTION
    Nothing on my truck or engine are stock, 28 to 31mpg !:cool:
  5. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    dam-28-31...i wish i was getting that much...need a tune up badly
  6. TRUCK ACTION
    Make the engine breather better , K&N air filter & good exhaust is the first step always!!:cool:
  7. Biggja22
    Biggja22 Newbie
    Twin Falls, ID
    Looking
    Just got the truck a week and a half ago it definitely needs tuning. I've leaned out the stock carb some but haven't got into timing or air flow but I'm getting half of what I should be getting by the looks of it.
  8. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    i just figured mine the other day and came up with 28 mpg. that's with a bone stock motor that just had the top end of the motor re-built. i live in the mountains so my mileage is prob a bit lower than someone that wouldn't have to pull those long grades up and down all the time. motor has 140k miles on it...
    oh and mine's an 87 and carborated
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    About 17to20 mpg.running a little fat . built bottom end built head/cam synchronized weber 34dgev running a 4 speed on 205/45/16
  10. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Cone intake and swapped to passenger side, fresh plugs wires cap rotor pcv, fresh fuel filter and injectors cleaned last summer, 2 1/4 exhaust from header back. I romp on it everywhere all day long
    24 city 33 highway with a tail wind with my stocks, 17's or 18's doesnt really matter
  11. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I get 22 with my foot in it city driving on 18's draggin' all the way...:D
  12. Biggja22
    Biggja22 Newbie
    Twin Falls, ID
    Looking
    I definitely gotta dig into this thing. When I got home from work today I've driven maybe 70 miles and I'm under 1/2 tank left. Grrr
  13. NavyMC
    NavyMC Member
    TN
    78 SR5
    Just a thought here, but you shouldn't be relying on the fuel gage for the MPG estimate. I have been fighting with my 78 for some time now and its fuel sending unit, which has the float and reostat for the fuel gage. I thought I got it all fixed and it reades accurately for about the first 100 miles, then is quickly goes to zero! So i have to track miles from when I filled last. I do get about 22 MPG with a newly rebuilt 20R, weber carb, and no other mods except the tires are bigger than stock. If I had stock size tires I am sure I would get a whole lot better AND if i tweaked the timing back to lose the "gydeeeee up" then I would surely get around 30MPG.... Just some thoughts though...
    Cheers!
  14. Biggja22
    Biggja22 Newbie
    Twin Falls, ID
    Looking
    I'll be calculating when I actually fill again but that gauge has just been dropping like a rock since I filled it as this is the first tank I've run. I've got the starting mileage written down.
  15. NavyMC
    NavyMC Member
    TN
    78 SR5
    biggja22, I hear you brother about it falling like a rock. Thats exactly what mine does after 100 miles. I would almost bet money that your engine is not consuming more that you think. I would also bet that it needs a tune up as well like you stated and that will certainly help. In my own experience, I have never seen a little 4 banger engine eat gas fast enough to drop the fuel gage to half in 70 miles. Thats DRINKING some gas. Maybe in a big block chevy that is all supped up or a Ford 460 engine (like I used to have)!!!!!! All good, update your post when you find out what is hapenning!!!
    Cheers and good luck!!!!
  16. macawilial
    macawilial Veteran
    Born and raised in San Diego
    I'm getting 24mpg.
    On my 81, I do about 70mph highway speed but my tires are shorter compared to the factory ones. My rev is a hair higher because of it
  17. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i'm averaging 25.9 ive gotten as high as 27.4
  18. alowe
    alowe Newbie
    Breaux Bridge, LA currently
    83 base model
    I drive for Dominos pizza and sometimes use my toyota for a shift and usually average a hair*under*25mpg. Driving to my grandmas 57 miles away strictly hwy i averaged 29 mpg round-trip in my Toyota. In July I bought a 94 escort with 115k miles for Dominos driving. Average 28-30 ac on in the escort. Not a Ford man AT ALL but I love my Toyota tooo much to put so many miles for dominos. My yota is mostly stock setup such as carb, exhaust, egr, million miles of vaccuum lines, stock tire size. The Toyota has over 200k but the 22r is a fresh rebuild. Around income tax time I do plan on doing 2-1/4" exhaust and Weber 32/36 carb on this '83 like i had on my 93 before some a**hole torched it. I would get a solid 28mpg in my '93 driving for work.
  19. Hazard
    Hazard Member
    Spokane, WA
    '77 Pickup (automatic)
    I'm getting about 0.0 miles per gallon right now. (the carb is still awaiting rebuild).
    My DD, the 85 pulsar, gets 35-40, and i'll likely continue to drive it to work.
  20. veedubfreak86
    veedubfreak86 Enthusiast
    PNW
    89 toyota ex-cab 2wd
    Mine is kinda not really aplicable but i will add it anyways
    Mercedes OM617 turbo Diesel swap W/stock tranny
    front 16x8 225/45-16, Rear 16x9 245/50-16 conquest wheels
    30-35 in town 40+ freeway
