91 standard cab build......
Discussion in '1989-1995 Build-Up/Project Threads' started by stroked90hatch, May 20, 2012.
  1. DannyBoy
    DannyBoy Enthusiast
    Tacoma, WA
    91 xcab
    this'll be gorgeous when its done. i can already see the compressors and shaved errrrrrythang ;]
  2. stroked90hatch
    stroked90hatch Enthusiast
    Gonna have a 8 inch raised bed too cover it all.....and I'm not really into shaved look gonna atcually keep all the factory black handles and funtionable tailgate.....gonna jus do a roll pan and only shavin gas door
  3. stroked90hatch
    Scored a set of brand new belltech spindles for 50 bucks shipped......
  4. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    LUCKY!!! :waytogo:
  5. stroked90hatch
    Firewall marked out for cut....gotta make new floor pan templates cause driverside is rotted bad
  6. stroked90hatch
    Since driverside floorpan was rotted out bad figured I do both floorpans jus soo they matched...lol
  7. DannyBoy
    DannyBoy Enthusiast
    Tacoma, WA
    91 xcab
    relocating the tailgate handle to the inside retains functionality, plus it looks nice IMO. its on my (growing) list of things to do. :waytogo:
    nice fab skills:bow:
  8. stroked90hatch
    Got low profile trans tunnel basically done now add some more fillers then gotta start the driveshaft tunnel and wheel tubs....
  9. stroked90hatch
    I get too work on it couple hours a night if I'm lucky.....right now I'm in the middle of doin all fab work on my buddys harley...its a 87 sporty wit 1100 evo I believe....200 rear tire dropseat hardtail.....4 inch drop seat....4 inch stretch...I did the hardtail on it....mounted the fender and tank.....jus mocked up the oil tank and kick stand tonite.....its all back too bare frame soo I can tigg weld all the mounts and bungs....we also changed the bars too a real low pro z bar....
  10. stroked90hatch
  11. Yotaforce
    Yotaforce Enthusiast
    Sacramento, CA
    94 xcab
    Gorgeous work on the body drop man. I can't wait to see what else you do. Referring to earlier when you said you were going to keep it pretty factory, are you going with factory paint codes and everything?
  12. stroked90hatch
    Naa gonna have a matte finish paint....with gloss black 18s....factory tails/frontend....
  13. Yotaforce
    Sacramento, CA
    94 xcab
    Sounds sick. Keep it up.
  14. stroked90hatch
    Yaa...I'm gettin excited...cab should be off this weekend ill weld underside/seam seal and paint.....then Ill z frame do tranny xmember and lower motor
  15. stroked90hatch
    Got the driveshaft tunnel done tonite.....
  16. stroked90hatch
    Firewall tubs about 90 percent done....jus need too clean up and trim the edgs slight overhang.....
  17. pivins45
    pivins45 Member
    Wilmington, North Carolina
    94 Pickup Ext Cab
    looks good bro. keep up the good work... awesome pics.
  18. Yotaforce
    Sacramento, CA
    94 xcab
    Good pace too. Wish i was doing the same thing right now.
  19. stroked90hatch
    Scored completly rust free fenders of a runner today for 40bucks.....
  20. stroked90hatch
    Got the trans crossmember built and ready too z frame....
