Whistle/ ticking sound when accelerating
Discussion in 'Engine/Drivetrain' started by -Jacob-, Aug 20, 2012.
  1. -Jacob-
    -Jacob- Newbie
    Bendigo
    1991 2.4L rn85 Petrol
    Hey there need some help desperately, trying to diagnos a engine issue where when accelerate I get a loud ticking/ whistling sound at the front of the cab almost like marbles in a tin. Also notice it sounds worse when taking off with the clutch then accelerating , is this a worn clutch or accelerater cable doesn't sound right and would love to fix it ASAP. Any tips or help would be greatly appreciated
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Have any lose of power ?
    Clutch feel like its slipping ? I would pull the valve cover and check your valve springs and rocker arms
    These motors tick buy nature but if it's a large tick might wanna check under the valve cover specially if you have a bad idle or lose of power
  3. Litneon
    Could also be an exhaust leak?
  4. dillinja666
    valves out of adjustment/timing chain....
  5. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    check the heat sheild that covers you echaust manifold. might be loose.
  6. -Jacob-
    -Jacob- Newbie
    Bendigo
    Yeah clutch slips a little mate, so if I check both those what should I be looking for?
  7. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    could also be a worn pulley bearings...
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Well if clutch is slipping a bit might have some broken pressure plate springs rattling around and a worn disk not a major problem just maybe time for a new clutch and throwout bearing as far as checking your valve springs u wanna look closely at all your springs to see if u have broken one I've seen them break and still work but make some chatter u can turn the motor by hand with large deep socket on the crank pully and watch your valve train move .let us no of any news
    Worn throttle cable ? Don't follow if its starting to split or crack pick a new one from junk yard
