Hey guys i just wanted some advice. I want to lower my truck which is the best way to do it. Im new at this so anything helps thanks so much. Here are some pics of the current state of my truck.
Go 3/3 or 4 front/3" Blocks. Can Go torsion all the way up front. But when you do alignment you going need shims. Going need to remove bumpstops and put low profile ones in place. Also shorter shocks. 69 Camaro Shocks worked perfect for me in the front. Might also need smaller tires. Those look like 18s? Might have to go 35 series so no rub front fenders.
Thanks so much for the info. Yeah I think im going with the 3 in blocks and the torsion. I was also looking on buying smaller shocks, thanks for the info on the camaro shocks. I was also thinking on buying new rims and tires. Hopefully everything goes as planned
