Just installed 4Runner Seats in my 88 P/U
Discussion in 'Interior/Electronics' started by ResidentG33k, May 27, 2012.
  1. ResidentG33k
    ResidentG33k Guest
    Installed some gray-ish seats from a 4Runner that looks like this one:
    Appears to be a early 90's 4Runner. Only two bolts from the drivers seat and two bolts from the passenger seat will have to be drilled, otherwise the other 4 remaining bolts lined right up and went in no problem.
    Here's a picture of them in my truck. As you can tell they're a little dirty but otherwise in decent condition. A small tear on the drivers seat.
    After the seats installed, I still have room for subs behind the seats too. Maybe two separate 12" Subs or just two 10's. I can snap a photo later of the room behind my seats. Also since removing my bench seat, thats for sale if anyone is local and interested. The bench seat is a vinyl/leather blue seat.
  2. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    pic
    Can you post picture of bench seat?
  3. ResidentG33k
    ResidentG33k Guest
  4. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I have the same ones but am getting rid of em soon. Takes away too much legroom. Do yours have the lumbar / outter adjustment too? The driverside one I got does.
  5. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    Being 6 foot i cant put subs..i want some seats like that..maybe some SI seats
  6. ResidentG33k
    ResidentG33k Guest
    Yeah they have the lumbar support and stuff. I slide the drivers seat back enough and I still have leg room and room behind.
    I'm 6'1" and I have enough leg room. I guess my torso might be taller then my legs. I could probably put 10" Subs behind the seats. The 4Runner Seats are great IMO. They sit a little higher then I'd like. I thought they'd sit low but I can recline the seat a little bit and its fine.
  7. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    I'm 6'3. Runner seats just feel way too far forward for me.Gonna put my bench back in soon till i find lower profile seats
  8. nachizzle
    nachizzle Member
    socal
    88 2wd pickup
    Thats the kind of seats im looking to put in mine. Looks good
