Do i have to use a weber?
Discussion in 'Engine/Drivetrain' started by southbound dee, May 4, 2012.
  1. southbound dee
    southbound dee Newbie
    Gainesville fl
    My problem is i bought an '87 22re that was converted to carb. but the carb is gone, so is there any thing i can get from the junk yard that would work just so i can start the motor and see how it runs before i spend for a new weber?
  2. burnzya
    stock carb. everything on mine is disconnected except brake booster, vacuum advance, and fuel cut solonoid and it runs great.
  3. southbound dee
    Gainesville fl
    stock carb from what year this is what im working with...
  4. southbound dee
    Gainesville fl
    not sure if the intake manifold is 22re or 22r
  5. burnzya
    the 22re is the fuel injected version of the 22r. if it takes a carb it's a 22r. you just need to find a carb that goes to a 22r and it should work.
  6. southbound dee
    Gainesville fl
    a carb from a 22r ( SHOULD WORK?) or will it work:verdict_in:
  7. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Yes it will work but you will also need the black peice that goes in between the intake and the carb
