transmission ???
Discussion in 'Engine/Drivetrain' started by jdr492, Apr 19, 2012.
  1. jdr492
    jdr492 Member
    spring, tx
    It looks like I am about to buy a white 76 with 90,000 miles on it. if i do get it, crossing my fingers, i will eventually put a turbo 3rz in it. it is an sr5 with a 5 speed tranny. my question is this.... is it likely a w series transmission?
  2. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    If your going the turbo route you should look into the 2rz engine, handles boost better than the 3rz
  3. jdr492
    jdr492 Member
    spring, tx
    I have heard that. if it happens, crossing fingers once again, it'll have forged internals and the head will be built. the price on a 2rz is a bit cheaper. i thought about a 2rz and bore it out a little but i've also heard there is a problem with the amount of head gasket surface betwen cylinders if i was to do that. is that true?
  4. TRfknD
    TRfknD Veteran
    96 Taco / 05 Tundra
    Yup, 3rz's bottom end tends to blow up! lol Go with the 2rz and you won't regret it.:evil:
  5. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Im not to familiar with those motors, but there are quite a few guys on here that have done the swap as well as boosting them.
    Try the searching it on here there are a couple of build threads on it
  6. jdr492
    jdr492 Member
    spring, tx
    just got the word that the truck is mine.... Yay!!! i still need to figure out what transmission is under the truck.
  7. dillinja666
    Personally I would just put a w58 in it, so it wouldn't matter what it comes with or the mileage on the motor since you are swapping it anyways.
  8. jdr492
    jdr492 Member
    spring, tx
    i just wanted to see if it was gonna be strong enough to hold up to what i'm wanting to get out of the motor. i'm expecting 550+hp. if i've got to search for a w58 then so be it.
