fuel neck
Discussion in 'Engine/Drivetrain' started by yota4life, Mar 19, 2012.
  1. yota4life
    What could I use to make a new fuel neck.
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Do you have a pic of the tank you are working on so I can get and idea of what will work?
  3. yota4life
    Its just the stock tank. But its in the rear an under a 4runner body. I just need to shortened it but if I did tht it would kink it. So I wanted to get a 45° angle an put tht on the tank an reconnect everything. But I know regular rubber will disenegrate from the fuel
  4. stevemcq
    stevemcq Newbie
    Mosinee, WI.
    1988 Toy 2wd, 1987 Toy 4wd
    Most parts stores stock fuel fill hoses, some universal stuff too. Just measure your I.D. on both ends of the stock hose and tell them you need one with a 45 degree bend. I'm sure you be able to find something. Several years back I bought a universal length that was wire reinforced so it wouldn't kink when bent, I think it was $45 for 2 feet.
  5. TRUCK ACTION
    Just remember being in Ca. you have to have the stock restricter in there, or you fail smog check!!:cool:
  6. yota4life
    Ya I know truck action. I just need the rubber part. Ill check my local parts stores today
