74 Hilux : Weber Carb - Pool of Gas Overflows
Discussion in 'Engine/Drivetrain' started by Lostandconfused, Mar 7, 2012.
  1. Lostandconfused
    Lostandconfused Member
    Good People of TM --
    I finally got this beast to to turn over and start!
    It was going to the smelter to become slag, and I saved off the flatbed.
    It didn't have an engine nor fenders or lots of other things.
    Put another 20R engine in it.
    After finally working the wire harness, I finally got the old beast to turn over and sustain for a f seconds via starter fluid.:clapping:
    Now the problem is the carbuerator. It's not stock. It's a Weber two-barrel.
    When the gas comes in from the fuel filter an into the carb,it literally floods to the point of filling both barrels and spilling out:looney:
    I know it's an issue in the carb, but where and how to address? Some people tell me to clean it out, which I did. Still the problem persists.
    Aside from replacing the Weber ( Can a Weber even work on a 20R?) with a stock carb, what can I do?
    Many thanks!his project has taught me much about cars and dealing with frustration.
  2. dillinja666
    float is stuck down. take off the top 4 screws and clean out the float boal of junk
