Help!!!! 2wd coil front suspension conversion
Discussion in 'Suspension/Chassis' started by Ridi-Q-Less, Feb 27, 2012.
  1. Ridi-Q-Less
    Ridi-Q-Less Member
    Kauai,Hawaii
    92 single cab 22r
    I wanted to do a coil front suspension on my 91 2wd Toyota pickup. Wanted to to know if any one has any info on how to do this and what parts I'll need.
    Any helpis most appreciated. :waytogo:
  2. dagnisaun
    dagnisaun Enthusiast
  3. TwinTurboTaco
    TwinTurboTaco Enthusiast
    Space
    92 2X
  4. Ridi-Q-Less
    Ridi-Q-Less Member
    Kauai,Hawaii
    92 single cab 22r
    N e one know I'd the qa1 coilovers can work with the stock uca
  5. burnzya
    no it won't with a completely stock u.c.a. at a minimum you'd need to clearance the center out to clear the coil. and then you'll need to get creative with how to clear the stock u.c.a. cross shaft with the upper coil over mount
  6. Ridi-Q-Less
    Ridi-Q-Less Member
    Kauai,Hawaii
    92 single cab 22r
    Ok thanks burnzya guess gonna need a cando upper arm for this. As for the upper mount creative is my middle name. If it can be welded it can be made.
    Best sticker I seen. "don't worry I welded it" hahaha
  7. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    I'm working on a coil over arm kit for the Toyota
  8. Ridi-Q-Less
    Ridi-Q-Less Member
    Kauai,Hawaii
    92 single cab 22r
    What's the price range on ur kit??
  9. TheLoLux
    Simi Valley, CA
    $700 for the hole arm kit. I'm going to see if I can get a deal on qa1 to sell for the kit to
  10. Ridi-Q-Less
    Ridi-Q-Less Member
    Kauai,Hawaii
    92 single cab 22r
    Ok so around 1-1200 for a conversion
  11. TheLoLux
    Simi Valley, CA
  12. Ridi-Q-Less
    Ridi-Q-Less Member
    Kauai,Hawaii
    92 single cab 22r
    Damn for that I could str8 axel it hmmm what to do what to do?? Grounded= dodging speed bumps bumped when it rains. str8 axel= launching speed bumps but tire tickets on the daily bases. And pray for rain. Hummmmm what do you guys think
