Has anyone put 4 point harnesses in a regular cab pickup? I'm looking to do just that, but would like some suggestions on which ones work best. Thanks, Mike
If you want to use harness I would build a cage in the cab and weld tabs to the cage to mount the harness. That's the safe way to install the harness.
Thanks!! Yes, I planned on at least a roll bar and side braces, with a bar behind the seats for the shoulder straps. Not sure about a full cage at this point.
