300 rgm kit vs weber 38 opinions welcome
Discussion in 'Engine/Drivetrain' started by Osage, Dec 18, 2011.
  1. Osage
    Osage Newbie
    Oklahoma
    80 hilux shortbed 4x4
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I think for the amount those are you should go all out and buy my weber side drafts lol. other then that I dont have any experience with either of those setups.
  3. Osage
    Osage Newbie
    Oklahoma
    I'm really new to toyota engines, built a dozen or so sbc and have done some drag racing, but when it comes to yota gear i'm at the mercy of the might google search engine so feel free to suggest any other carb options, cheap + good is my favorite way ;)
  4. V8_TITAN
    Tampa Fl
    89 std cab
    well what are you trying to get out of your motor, or at least with your carbs. if your looking for mpg go with a weber 32/36, if you want the most hp out of the motor go side drafts. the 38 is the biggest weber down draft I beleive. I dont know anything about that jeep thing though.
  5. oldschool64bus
    oldschool64bus Veteran
    Boise, Idaho
    1983 SR5 4x4
    all I know is my truck had a 38 on it when I bought it, slightly bigger than stock cam and full exhaust, I could BARELY get 13 mpg out of it and it was so over carbed it was fouling the plugs and guttless as can be. On the 38 both barrels open at the same time unlike the 32/36 where the 32 opens and then when you get on it the 36 opens up too
  6. IronNam
    I say 32/36
  7. Osage
    Osage Newbie
    Oklahoma
    What I'm after is dependability first, power 2nd, i don't wanna overcarb it. this is another place selling the same kit only @ a higher price, here is there input on it.
    Contact US! "John's Foreign Engines"
    This may be the best carb you will ever find to beef up your 4 cyl.!
    Manual choke progressive 300 RGM
    This is a brand new carb kit
    Weber 38 Outlaw performance with mileage better than the 32/36 Weber
    This is a complete carburetor kit!
    Replace your worn out or leaking carb or boost your performance .
    This is a not a Weber brand Carb
    Kit comes complete with everything you need to bolt it on!
    This is a manual choke carb and kit comes complete with everything to install
    Carburetor, adapter, all gaskets, fuel line, bolts, linkage, chrome air filter assembly and choke cable
    It is a performance quality replacement
    it will add about 10-15 horsepower!!!
    And increase your fuel mileage
    You will say WOW!
    Easier to install and tune than the old school Weber carbs
    Perk up your Bad Boy !!!
    adds a lot of horse power
  8. V8_TITAN
    Tampa Fl
    89 std cab
    Im NOT buying their "performance claims" especially when they say its not weber brand which means its a knock off.
  9. oldschool64bus
    Boise, Idaho
    1983 SR5 4x4
    My EMPI 32/36 gets better MPG than the Weber 38 did, out of the box and basic tune I went from 13 mpg to 19 around town. The reason 32/36 get better MPG is most of the time you are driving around on the 32
  10. GrantH
    GrantH Addict
    Hattiesburg, MS
    I would go with the RGM kit. Weber's are finicky little monsters. I don't know ANYTHING about the RGM kits, but they look better and the throttle setup looks like it would work better if it is in fact the rod linkages.
    Just looks like a higher quality kit.
  11. Osage
    Osage Newbie
    Oklahoma
    I read that when weber employees went on strike the had an italian company build there carbs until the strike was settled, the carbs from that time period were said to be much better than the webers prior that were built before the strike, this same company is the one who are responsibile for this carb. Not sure if there worth a try or not, I'll dig deeper.
  12. GrantH
    GrantH Addict
    Hattiesburg, MS
    See if there is some sort of return policy on them. You will know in a few hours if they hold a tune and seem to like the motor. 30 day return would be more than enough time to make up your mind.
  13. 82shorty
    82shorty Newbie
    i got a 38 and i love it, i get abbout 20mpg on the street with no fouling, but on the track i richin it up and increase fual pressure, it works great when engine is built to handle it
  14. gooseracing
    gooseracing Newbie
    concord ca
    82 toy
    just run a 350cfm holley 2barrol cheap and runs like a champ
  15. 82shorty
    82shorty Newbie
    yes this is another good option, another budy of mine has one on his, the adapters are the same price and he actually gets a little better MPG then me, but the 38 is like a 400-425 cfm carb as well
