Clear needles?
Discussion in 'Interior/Electronics' started by Zombie Monarch, Jan 10, 2012.
  1. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    Anyone cleared out the needles on their clusters? Not sure if you even can on ours I want to say they are metal.
    -OR-
    Does anyone know where we can get clear replacement needles for our clusters?
  2. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    If you remove the needles you can gently scrap of the orange paint on the rear of the needle. I just repainted some orange on an extra cluster a while back. I don't know how good it would look just bare ???
    22R88
  3. Zombie Monarch
    Springfield, MO
    I'm wanting to clear the needles then wire up some LED's so I have a glow needle.
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I doubt it.. btw they are so brittle be very careful.. mine crumbled while i was taking it out...
  5. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    yes you can I did it before I repainted them white, check my build thread...dont scrape it off you might leave scratches on it that you will be able to see...use acetone or alcohol..they won't light up good at all because the light will not have anything to reflect against, unless you dont care what they look like at night
  6. joeynational
    PHX,AZ
    91 2WD
    and for this you will have to make a small circuit board with some LEDs on it that will mount directly under the needle, you will not get enough light on the needle any other way..I've tried it already and thats another one of my projects
  7. Zombie Monarch
    Springfield, MO
    Yeah I've done lots of research on them, thing if you scraped up the backside of the needle it would reflect/capture the light better? A lot like you would do with the DIY angel eye headlights made from clear curtain rods?
  8. joeynational
    PHX,AZ
    91 2WD
    yeah you could do that, "frost it" but then it wouldnt be clear, just white-ish
    here is a good example of how you would need to make an led board to illuminate the needles GOOD..its what i'm doing, except i'm going to use some PLCC-4 LEDs
    DIY: LED Instrument Gauge Cluster & Glow Needles
  9. Zombie Monarch
    Springfield, MO
    I had looked at that exact forum actually. That's how I was planning on doing mine.
  10. joeynational
    PHX,AZ
    91 2WD
    I love hidplanet.com I learned so much on there, you should get on there too! Your into LEDs and HIDs like me, great place to learn!!
  11. TwinTurboTaco
    TwinTurboTaco Enthusiast
    Space
    92 2X
    I scraped the paint off mine with a razor and then wetsanded where the paint was with 1500 to give it a frost. I have blue LEDs in my gauge kit and like the way it turned out
  12. Zombie Monarch
    Springfield, MO
    Can I get some pictures?
  13. TwinTurboTaco
    Space
    92 2X
    Here's some crappy ones. The blue led lighting is still a work in progress. I removed the green tint from behind the gauge faces, and once you that it makes bright spots and dim spots. It's not as bad in real life as it is in that second pic though.
  14. joeynational
    PHX,AZ
    91 2WD
    you have those dim spots because the light is not evenly distributed throughout the cluster...I used an LED strip vs just changing out the bulbs to fully and evenly light the cluster
  15. IronNam
    I know for sure my non tach cluster doesn't have needles that can be cleared
  16. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    how did you do this? i know i have read it here or on CustomTacos but id be damned f i can find it...Acetone?
  17. joeynational
    PHX,AZ
    91 2WD
    its in my build thread, check the link below..yes or sand it off or rubbing alcohol
  18. joeynational
    PHX,AZ
    91 2WD
    you are right, they are solid, I tried a glow paint that looked pretty cool but not the effect I was looking for
  19. joeynational
    PHX,AZ
    91 2WD
    here is mine
  20. TwinTurboTaco
    Space
    92 2X
    I tried acetone, but didnt like the way it was working. What I found worked best was just some 120grit by hand to start, and then once the white started showing switched over to 400 grit. Keep in mind even if you use standard bulbs your gauges will be brighter in the center like mine. Because on top of the green layer is a specially designed shaded layer that is darker and lighter in different spots to make the factory bulbs look even colored, and you have to remove that first before you can get the green off.
