cobra wheels on a 92
Discussion in 'Wheels/Tires' started by Wolf_Lehr, Dec 7, 2011.
  1. Wolf_Lehr
    Wolf_Lehr Newbie
    SW
    93 xcab
    Got some 98 cobra wheels their 17x9 and 17x10 (or 10.5). Dont know the offset just pick them up cause they looked nice lol. Has anyone ever ran these? I think i might have to bore them out, bit other then that will they be to wide or am i good?
  2. IronNam
    I ran 18x9 Mustang GT wheels on my truck, fit right on, I'm sure those cobra's could work.
  3. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I have 96 Svt Cobra wheel on my 92. They are 17x8 and Im running 225/45/R17 @ all 4 corners with no problems. Did not have to modify anything to make them fit.
  4. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    weird...was something change for the 94 trucks...cause everything says I have a hub bore of 60.1mm...But I just measured it and it's 67mm. Which means most 5x114 oem wheels will not fit.
  5. Beefed Taco
    Beefed Taco Addict
    I have Replica Cobra wheels on my 99 with a 89 axle. Hub hole worked fine, the specs are 18x9 +36 (offered in 18" and 19" diameter and 9" & 10" width and +36 or +24 offset) I run a 275/35/18.
    It's common to have to open up the bore on wheels when using them on the Taco and if I remember correctly the hubs require a 67.1 or bigger hole. (don't quote me though, I'd have to double check)
    These were a simple install with no milling required purchased new at Big O Tires.
  6. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    ^^^I love it!!!!
  7. IronNam
    are those fr500's?!
  8. Beefed Taco
    Beefed Taco Addict
    Thanks, me too!
    Yes sir...I had no idea since the paper work and box didn't say, but I was schooled on FR500's over on CT.:waytogo:
  9. Wolf_Lehr
    Wolf_Lehr Newbie
    SW
    93 xcab
    I was going to pick up a set of them fr500's for a ok price. I should have done it cause it looks niceeeeee lol. all i need is a drop and im going to call it a day.
  10. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    I'm sure most of us on here....has said the same thing at one time!!! LOL
  11. confused.rat
    confused.rat Enthusiast
    Springdale, Ar
    1993 Pickup Ext Cab.
    im trying to run some bullitt wheels and they bolt right on the front but i can barely turn without them hitting just about everything. i put a spacer on, i think 5/16th, and was able to turn full lock both ways. but the lug nuts barely have enough threads to grip on. how hard would it be to put longer studs on?
  12. YoudLooZ
    YoudLooZ Newbie
    Riverside
    1994 2wd std cab pickup
    1994 2wd with 18" cobra wheels
    i have no problems running 18's
