5 Inch Bodydrop on a 1994. Will 20's Fit.
Discussion in 'Wheels/Tires' started by schwartz3813, Nov 18, 2011.
  1. schwartz3813
    schwartz3813 Newbie
    Hilton Head, SC
    1994 Tacoma
    My trucks bodydropped 5 inches with a full bag setup. Its on steelies right now but i want to put some Boss 338's on it. Wanna go as big as i can. im sure 20s will fit but i wana make sure. my hoods already cut with the motor sticking through, i will cut more and put 24's... HAHAHA. But seriously does anyone know how big i can go. my front inner fenders are already cut and i have the 4x4 fenders as well. i just dont know anyone around here with rims i can try to test the fit. Thanks. Keep draggin
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    post some pics man. lay your truck flat on the ground, and measure from the ground the the bottom of your hood and that should tell you how big a tire you can fit.
  3. burnzya
    so you're pretty close to doored? if so you won't be fitting 20's. bodied to rocker, a super low pro 20 will just about touch the hood.
    they do make the boss 338's in 18 as well i'd go with them.
  4. schwartz3813
    schwartz3813 Newbie
    Hilton Head, SC
    1994 Tacoma
    ill check it out when I get back to the garage. I know itll fit 20's. I just wish I could go ridiculous and stuff 22s under there. I havent found any yotas rollin on anythin bigger than 20s.
  5. jeremystephens
    jeremystephens Enthusiast
    mississippi
    94 xcab
    ^^^^^^ theres a reason you havent seen it.... You can lay pinch on 22's with these body style thats it... Not rocker not door...You could lay pinch on 22's then build new rockers to make up the difference so it would appear to be rockered...
  6. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Im surprised nobody asked if your firewall is tubbed!!! I know I posted in another thread on here but I got pics of my buddies truck 6" body with 20's and they stick out like a sore thumb in the bed and the engine bay. He has to raise his fenders and pretty much do what Jeremy said and make fake rockers but pretty much just adding to bottom of fenders. Good luck.
  7. myPROJECT
    myPROJECT Member
    agree
  8. GrantH
    GrantH Addict
    Hattiesburg, MS
    Why would we ask that? If he's running anything more than 16 on a 40 series right now he's got to tub just to be bodied. At least on the 84-88 you do.
    I will never understand why people ask if something can be done, then say "I know it can!....but i've never seen it." Minitruckers have about worn out mods possible when it comes to putting wheels/tires under trucks and if it's not been seen before...there is more than likely a very good reason for it. You own a doored mini truck, you don't get the "cool" points from big wheels...you get them from being doored. Enjoy 18's and own a decently drivable truck.
  9. Litneon
    Wow. Well said.
    I've racked my brain to find combos that haven't been done, but face it, it's a '94. They've been working on modding that body style for 20 years.
