A/C and traditional body drop
Discussion in 'Suspension/Chassis' started by Dup, Oct 11, 2011.
  1. Dup
    Dup Newbie
    Beaumont,TX
    1993 toyota pickup
    I have a question for u guys can you have factory A/c and heat on a traditional body dropped 93 Toyota and if not what are the alternatives. It's sitting on the rockers
  2. yota4life
    I don't have ac or bodied yet but checkout vintage air or maybe you can get some lines custom made
  3. jeremystephens
    jeremystephens Enthusiast
    mississippi
    94 xcab
    all depends on wheel size because wheels size determines tubs.... You can with a little work to the blower box run a/c bodied on 20's
  4. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Yah mine sits on 17's and with a 2.25 traditional id have to slightly modify the outlet of the airbox into the cab then the interior box would need to be raised a bit. Not anything drastic there. With larger rims then yah you gotta worry about tubbing the firewall and then its moving the box and having to mod or make/run new lines since the box/condenser sits right on the area you tub same as the brake booster on the driver side.
  5. Suthrn98
    Suthrn98 Member
    A/C is overrated, and I live in GA where we have like 100% humidity and well into the 100's in the summer!
    Would you rather be cool and not cool with only bagged, or cool and not cool with a bodydrop?
