You decide if it's for your truck I'm just passing on what I've found. I havn't purchased one so, you will have to look on the site for info.Exhaust Header Toyota Pickup Truck 4Runner 22R 22RE rec - JTOutfitters
It looks legit and all, I may be willing to try this one out EDIT: I just looked a little more on the site and see that they do have long tube headers with a test pipe for $240 http://www.jtoutfitters.com/minitruck-4runner-headers-p-3869.html?osCsid=f2th5gcq71cg90bn48uuq5bm02 I still like the other set though, They seem like a good start to a custom built exhaust and easy to design it for clearance
You should go for the 4-1 header that gilpet posted. You with have more power. And with a test pipe you will have more power and a better sound. Just beware running a test pipe with no cat is not ca legal and will get you a fix it ticket. So if you are in ca keep your cat pipe for smogging. I actually might be interested in the 4-1 with the test pipe also.
Remember this..you get what you pay for sometimes..I have not ordered from them but a downey,or LCE or a Doug Throley would be the way to go to me..cheaper is not always better. I have found that out to many times.
^I second this.^ I'm about to go through the same thing with a header brand called OBX. I got a moderate review when i asked everybody here about that brand. But the header is used and already been modified to fit, so it'll be a little easier, but i met a guy with a Celica-Supra that has the same brand header. He said he had to cut pieces of the flange out to get it in. Also, the one you posted looks a lot like the Pace-Setter design. My 2 cents
