toyota motor swap!!
Discussion in 'Engine/Drivetrain' started by Dux_Trucks, Mar 9, 2011.
  1. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    I have a 1988 Toyota drift truck and im building a n/a 20/22r but I know that there is a power cap!! :duh:and anyone that has had power under there foot after a bit you want/NEED more power!:runaway: . . .
    I would love to keep the cost down ,not have to modify the oil pan and pick up (4age -4a silver/black top) wouldnt mind going v8 but still have the price cap and NEED a stick
    any help would be great!:waytogo:
    thank you for your time .:drunk:
  2. Dux_Trucks
    campbell CA
    bump? anyone have any idea's?
    I mean come on meow this is a toyota forum right? lol anyone know of a good rwd yota motor?
    Erwin Merida likes this.
  3. jeremystephens
    jeremystephens Enthusiast
    mississippi
    94 xcab
    1uz-fe is a lexus motor I would recomend. Cheap swap not really. Cheapest v8 swap would be a 302 probably
  4. Dux_Trucks
    campbell CA
    yeah I have thought about the lez v8 but the darn bellhousings are bank!! and I will NEVER put a 302 in anything lol I think I would do the mopar 318 before the 302 and a 350 before anything else lol
    thanks for the input tho ..
    anyone know the dimensions of a tundra v8 and standard trans?
  5. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Bolt in a 7m.
    Go from there
  6. Dux_Trucks
    campbell CA
    yeah the 7m is a good motor would only do the gte if I did it ... but it is almost the same weight as a sbc and they dont have a cheep aftermarket like the sbc dose
    what about the 2r or 3r maybe boosted?
    anyone on here boost one before?
  7. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Twinturbotaco has a boosted 2rz and predrazor i think, or someone with a 7x something. Seems like a bad ass motor.
  8. Raffaelli
    Houston
    82 Longbed 2WD
    Turbo = expensive!
    v8 = not so much, but still expensive.
    :shrug:
    Could easy spend 2+ grand on a sbc install.
    Brian (TRfknD) has a boosted 2RZ taco. Runs (or at least did run)really good. He's goin to the next step built wise. IDK how much he has into his truck/motor, but I bet its a lot.
    But a 2RZ swap takes a custom oil pan.
  9. TRfknD
    TRfknD Veteran
    96 Taco / 05 Tundra
    Turbo, is just expensive in general. With my 7psi build I have about 2 grand into it. Next step with internals add another 1,500 into the build. It should be fun at 15-20psi w/ cams!!! In general the turbo was the most expensive piece. The megasquirt I got specially built for my taco and had a friend wire it up for me so it's a plug n play to the stock harness for 300 bones. Not bad for a full standalone system! :waytogo:
  10. Exocet
    Exocet Newbie
    Tucson, Az
    85 SR5 4x4, 76 hilux
  11. Dalerman
    Dalerman Newbie
    I think this just inspired me to do a 3rz swap after i lower and stance my 88
  12. standardbyker88
    My vote is dodge small block. Using V6 Dakota bellhousing will bolt an R or W series
    Toyota trans to a dodge small block; depending on bellhousing year. (87-91 ax5 for W, 92-00 ax15 for R trans). Can get front or rear sump oil pans from stock cars/trucks, and they are pretty easy to build and don't need all the aftermarket valve train of a Chevy to run a mild cam.
  13. matthew babon
    matthew babon Newbie
    I hate half breeds. Did you go with a Supra?
