installing a/c
Discussion in 'Interior/Electronics' started by lincolnmania, Jul 13, 2011.
  1. lincolnmania
    lincolnmania Member
    Tremont PA.
    1986 22r 4 speed
    as soon as the parts get here......got a good deal on ebay, there are no 84-88 toyotas in the junkyards around here....also ordered a new receiver drier and belt and o ring kit.......now to find a slide in camper at a price i can afford.
  2. R-Tan
    R-Tan Enthusiast
    Apple Valley, CA
    88 std cab
    Post some pics during the install. sounds like you have some good projects coming up.
  3. lincolnmania
    lincolnmania Member
    Tremont PA.
    1986 22r 4 speed
    working on getting the evaporator housing installed......ac line holes ok.......the evap drain hole ended up a tad higher than i needed it to be, nothing some silicone cant fix tho.
    i replaced the seals on the evap box with some new self stick weatherstripping from autozone.
    i'm going to need some wiring diagrams if anyone has them handy........the evap housing i got appears to be from a fuel injected truck, it has a speed controller on top, so the harness will not directly pug in to my 22r truck...........the switch plugs in to a spot and i see that the fuse is there for the a/c system..........there is a probe stuck in the evap and the low pressure switch that need to be hooked up......is the a/c relay factory installed somehwere?
    i'll get some video tonite.......camcorder battery was dead last night sorry.
  4. kenichols29
    kenichols29 Member
    So how did your A/c install go?
