Ok did a transmission swap now have a few q
Discussion in 'Engine/Drivetrain' started by IBeSeeN, Jul 12, 2011.
  1. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ok so i went from a G40 transmission to a W56 i only have one issue the speedo drive cable is on the other side of the motor was wondering if they made a longer one cant find one anywhere... Thanks
  2. thundering02
    thundering02 Addict
    Fenton 63026
    lcengineering.com?
  3. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ok nvm i found out after i was installing i went to switch out the cable drive gear for the electronic and its about 1 inch smaller around for the hole how hard is it to swap in a electronic gauge cluster? and its a w55
  4. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
  5. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    after hours of looking around i finally think i found one of the 2 parts i need to buy to complete my w55 swap it's a Speedo Sleeve out of a 89 Toyota supra P/N 33404-22010 OEM Toyota
  6. dillinja666
    you know your 5th gear speed will be off right?
  7. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    why would the 5th gear be off? if all the rest are on?
  8. IronNam
    bump. was this ever resolved?
  9. dillinja666
    never mind...im an idiot. too many things on my mind at work and forgot the speedo cable is driven off the output of the trans...
    was thinking cause the 4 speed final ratio is 1:1 and the 5 speed is .85:1 that it would offset somehow...
  10. Ian Nexus
    Ian Nexus Member
    Torrance CA
    93 xcab 22RE 2WDAuto
    A43D Transmission 4th gear is 0.688
  11. IronNam
    .688 with 3.727 top speed was 187 on stock tires.... lol
  12. Ian Nexus
    Ian Nexus Member
    Torrance CA
    Top does seem a little tall doesnt it, no wonder it feels a little "lethargic" after driving my old C250TD Mercedes that I had back in England.
