can someone help please
Discussion in 'Engine/Drivetrain' started by silos92, Jul 11, 2011.
  1. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    ok so heres my problem last i was driving my truck when i suddenly hearing rattling from under truck like from the cat converter, then i noticed my truck was over heated when i got a chance to pull over it died on me well pulling off, i lift the hood and steam blowing every where, i let it sit for a while before trying to crank it over again, it finally turns over after many attempts and persisitance, but its starts smoking badly from the muffler and idling rough, anyone have any ideas? imo ithink its the cat conv and muffler are both shot:confused::confused::confused:
    sorry for being so lenthy just want to paint the picture, btw its a 92 22re single cab sb 2wd
  2. Str8Savage
    Str8Savage Member
    Hilo Hawaii SHC
    93 DX SingleCab 87 Single Cab Blue LowLux(RIP) 85 HILUX 4x4 87 HILUX ExCab 4x4
    Sorry homie but i really doubt its your exhaust system. Seeing that you overheated it to the point of it dying and then having a hard time trying to start it. Sounds like you blew your head gasket and maybe warped your head a little. That would cause hard starting because of loss compression due to the head gaskets failure and the smoking issue which is probably burning oil and coolant. If your exhaust smoke is white and smells like kfc colslaw you can bet your head gasket is gone and i really wouldn't drive it to prevent further damage. Look into it.
  3. TRUCK ACTION
    When cold check your coolant level,do not run with low or none there!!!
    If steam was present sounds to be coolant related!!
    Find the cause,broken or damaged hose,radiator,water pump,or the valve @ the passenger side of the block that water flows through,smog related item,when @ running temp. closes & takes the engine out of cold start!If bad will cause the cat to fail!
    If the cat it will have a rattle running or just banging on it most of the time! Also can produce a bad smell!:cool:
  4. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    yep sound to be a blow head gasket with all the white smoke out of the exhaust. i don't recommend even starting it so you don't damage it more.
  5. jetas
    Yep ur head gasket is gone!!
  6. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    thanks guys, so sounds like im in a hella jobs switching that out but i dont think it should be too expensive to fix, kinda sucks though i have no tools since somebody stole them from my truck along with my radio and they ripped up my dash to get to that, but at least i still got the truck lol
  7. IronNam
    dang that sucks man, I know how it feels to get jacked.
    find a few friends. engnbldr.com MIGHT have a headgasket kit or something to boot. talk to Ted if you need help. We have a few members in Georgia.
  8. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    cool thanks cinanmon
  9. jetas
    Its easy as hell bro. Just take ur time. Can get it done in one day
  10. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    well hopefully if this rain clears up this weekend i can get this down, i'll post up my results when i finish
