Alternator removal help 88 Toy
Discussion in 'Engine/Drivetrain' started by 22R88, Jun 19, 2011.
  1. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    22R engine. Does the alt come out through the top or through the bottom ? Looks to be a tight fit. 22R w/ Pwr steering and A/C plus air pump.
    Thanks
    22R
  2. yota4life
    On my 91 I think I took it out through the bottom after I took the fan shroud out
  3. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    mines came out the top but with no pwr steering and a/c
  4. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    w/steering and all that you might have to remove it from the bottom
  5. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    you are most likely going to have to remove the lower radiator hose, ive done mine so many times that i found a good way to knock it out without removing anything.
  6. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    yea ^^same here mine comes out the top
