Salvage title?
Discussion in 'Off Topic' started by yota4life, Jun 16, 2011.
  1. yota4life
    Has anyone in CA registered a salvage title truck or car before? What did you go through?
  2. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
  3. yota4life
    Ya my brother did it awhile back an it was just a brake an light test. Just wanted to get others opinions before buying this 4runner shell
  4. jetas
    Just do et!!
  5. SD YOTA
    very simple inspection. the one i went to did a full lights function visual test, drove it down the street to check the brakes and that was it. done and over in about 15 minutes.
  6. yota4life
    Ok sik I'm just buyin it for the shell I'm putting the runner body on my bagged reg cab frame
  7. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    I'm pretty sure you can swap the body and just keep it registered as a truck, since thats what the frame and motor is from. Because if the shell was a V6 truck, then you will need to get it refereed as a 22RE swap.
  8. yota4life
    I talked to Tom the owner of the old bagged 4runner an he said his was register as a runner with v6 but kept smogging as a 4 cyl an passed everytime. I was gonna sell the reg cab an title to a buddy
  9. Twisted Minis
    Poor Cal
    1980 Toyota
    Just saying, you get pulled over by the wrong cop, you will have to referee it.
  10. yota4life
    Ya I get what your sayin man. But what if I get pulled over an it says a truck an it's clearly not?
  11. Twisted Minis
    Poor Cal
    1980 Toyota
    That one is easier to get around. A body swap is legal, just tell them its on the pickup chassis, but the pickup was too damaged, or rotted out, and you found the 4Runner body and swapped it.
  12. yota4life
    What about the 4runners vin number on the dash? Or should I keep the dash I have now? And if I did tht could I just keep my reg cabs license plate and put it on the runner?
  13. Twisted Minis
    Poor Cal
    1980 Toyota
    Ya it would still be registered as your truck, so keep your plates. You are just replacing a body that is "unusable". Which has been done before. I would keep your VIN, I think you can just drill the rivets out if the 4Runner dash is nicer, or just swap yours.
  14. yota4life
    Alright that's what I'll do then I'll just tell my buddy I need the title an he can use the 4runner title haha
