Check this out!
Discussion in 'Off Topic' started by 22slow, Jun 3, 2011.
  1. 22slow
    22slow Member
    San Diego during the week, and Az on the weekends.
    1990 2WD Sb and 1982 4WD Lb
  2. dillinja666
    i think thats my buddies truck, cept i dont remember his bed being so rusted. good luck, if you dont pick this up i might. could always use more turbo's in the family :)
  3. IronNam
    worth the buy... has a locker!
  4. jetas
    looks like a good buy except for the mileage. Aren't that many miles bad for a turbo motor?
  5. SD YOTA
    its a toyota...... with those miles, it just broke in.
  6. jetas
    Hell ima see about getn me a turbo yota just dont want one with an as$$load of miles if its bad for the motor
  7. 22slow
    22slow Member
    A head gasket is not that hard to replace. That is all I would be worried about. Cometic head gasket, ARP head studs, and it should last a while.
  8. IronNam
    It's also a 22Rx
    **** will run forever.
    and 2xx,xxx miles is pretty damn low.
    As long everything else is mechanically fine.
    no leaks and drips? NICE!
    And yeah, HG should be simple. I'd remove the CT20 turbo for a CT26(b) or adapted T4/T3, anything more efficient than the stock turbo. And at least intercool it in some shape or form. Anything to help out the motor. With that, the truck would be peppy and run even better, cooler too!
