Bags for an 86?
Discussion in 'Suspension/Chassis' started by dc_style, Jun 3, 2011.
  1. dc_style
    dc_style Member
    St Paul, MN
    1967 Toyota Stout
    I have been trying to find more info, I understand there's the search button but I'm just not finding anything. I found an 86 xtra cab running drivetrain that I'm going to swap my 67' Stout body onto. What are you guys running for front and back? Is there a specific kit? Thanks guys.. appreciate the help!
  2. Litneon
    It doesn't have to be specific to that body style. Toyota didn't change the suspension from then into the 89-95 version, so any of those setups will work.
    What's your budget?
  3. dc_style
    dc_style Member
    St Paul, MN
    1967 Toyota Stout
    so 89-95 will work? my budget is along the cheaper end. I'm completely new to the mini truck scene so I am trying to figure out a list of what I need for this drivetrain before swapping the body on. help? thanks!
  4. TRUCK ACTION
    84-88 Is what you search for.
    Price is all over ,just make a list of what you will need ( want) ,& go from there!
    Do it right & once!!
    Don't use a tee fittings between bags as this will effect handling ,air will transfer from one side to the other!
    Any welding do or have done with 220 welder,this is your suspension,& it's not just your life!!!:cool:
  5. dc_style
    dc_style Member
    St Paul, MN
    1967 Toyota Stout
  6. IronNam
    anything frame or suspension related needs 220V welders. You want to get that weld in.
  7. dc_style
    dc_style Member
    St Paul, MN
    1967 Toyota Stout
    input on the links?
  8. yota4life
    Both kits look good. Not cheap parts either.
  9. dc_style
    dc_style Member
    St Paul, MN
    1967 Toyota Stout
    which one would your recommend?
  10. jetas
    I wouldnt buy any components from ebay. Sh!t like that id rather find a reputable retailer to order from
