Drop spindle install, what else to replace?
Discussion in 'Suspension/Chassis' started by Central Scrutinizer, May 25, 2011.
  1. Central Scrutinizer
    Central Scrutinizer Member
    CT
    89 xcab
    Hey guys.
    I'm about to order some drop spindles and was wondering what else to replace while I'm at it. My truck has been bagged on the stock spindles, and the tie rod ends look like they have taken a beating. I was going to order these
    How about ball joints? Anything else?
    TIA
  2. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    It would be a good idea to replace as much as you can up front, just think the more new parts the better the ride :). Im about to do my drop spindles and im going to replace just about everything under there haha
  3. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    Its your truck dude you know more than we do why not just give it a good inspection? If miles are high maybe new wheel bearings, seems like your on the right path being its been bagged before i would do as much as you can afford like it was said above, gl!
  4. jctoy29
    jctoy29 Addict
    surprise,az
    Upper & lower ball joints and outer tie rods if worn or have any play in the, and shocks too.
  5. Central Scrutinizer
    CT
    89 xcab
    yeah, i'm puttin together a parts order, didnt want to get half way through the job and not have something, i'd rather have it in advance.
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Just remember that the toe changes alot with the spindles. Just figure an alignment bro. :waytogo:
  7. Central Scrutinizer
    CT
    89 xcab
    yeah i remember reading that somewhere, someone posted up a few measurements to take to get you straight enough to get to the alignment shop. Does anyone know where that is?
  8. Central Scrutinizer
    CT
    89 xcab
  9. merrick
    merrick Member
