ok im really stumped please help!!!
Discussion in 'Engine/Drivetrain' started by silos92, May 8, 2011.
  1. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    Ok I have a 92 pickup manual tranny, and a 22re, my problem is I went to drive my truck this afternoon I put it in gear and it does budge i take my foot off the clutch and it does die just keeps idling!!! Please anybody tell me what might be the issue here, thanks for any help
  2. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    Probably the clutch master or slave cylinder.
  3. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    Well I bleed out the slave cylinder a few weeks ago, what do you suggest for the clutch master???
  4. dillinja666
    sounds like you need a clutch. if the master or slave wasnt working you would not be able to shift it or even start it in gear cause it would take off on ya.
  5. SD YOTA
    yea....... sounds like the clutch is gone. x2 :waytogo:
  6. GrantH
    GrantH Addict
    Hattiesburg, MS
    make sure you still have a clutch fork lmao. you never know! it could have broke, slipped, or whatever else. i've never seen a clutch SO bad it wouldn't engage even the slightest.
  7. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    How and where do I check for the clutch fork?
  8. LowLife89
    LowLife89 Member
    inland empire cali
    1989 Toyota pickup
    Its probably the clutch, when I bought my truck the clutch was so worn down it would not engage at all and when I pulled the trans the flywheel was blue and burnt from overheating
  9. 808ra29
    808ra29 Member
    Hilo, Hi
    prob clutch. killed a few in my day and it sure sounds like it.
  10. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    Well looks like its time to drop the tranny, damn I was for something simple, but thanks guys for the input really appreciate it
