carb adjustment
Discussion in 'Engine/Drivetrain' started by Shane Co., Apr 19, 2011.
  1. Shane Co.
    Shane Co. Newbie
    dewey, az
    1980 single cab long bed
    i'm having issues getting my 80 20r to run right. i cleaned out the fuel tank, replaced fuel filter and pump, and have cleaned out the carb. does anyone have any tips or tricks on how to tune the carburetor? any help would be greatly appreciated.
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Carb
    Is it a stock carb? What are the symptoms?
  3. Shane Co.
    Shane Co. Newbie
    dewey, az
    yes, it is the stock carb. sometimes it will run fine, and then it will just start dumping black smoke out the exhaust and it seems like it's running super rich and won't idle unless i pump the pedal.
  4. Malessohomegrown
    Malesso,Guam
    float ball
    Sounds like your float ball might be gatting stuck.
  5. driftwhat
    driftwhat Member
    california
    1970 toyota hilux
    Rule of thumb when adjusting your carburetor is backing thel adjustment screw all the way until it seats and then go 2 1/2 turn. Start your engine and tune from there. If it still idle rough slighty open up your mixture screw until the engine just barley running smooth. If it starts running rough again your too far off and would run rich. NOTE: Alot of time 90% of the problems with idle and running rough deals with your ignition timing!
  6. Shane Co.
    Shane Co. Newbie
    dewey, az
    i'll pull it back off and check. thanks for a direction lol.
    i pulled the mixture screw all the way out and noticed a small ridge towards the finest point of it. is that correct or am i going to have to replace it?
  7. dillinja666
    thats correct, thats the seat.
  8. Nook
    Nook Addict
    oregon
    If it has a ridge worn around the fine tip, thats not the seat, seats in the carb, the needle has the ridge worn in it from being over tightened, and should be replaced.
  9. Shane Co.
    Shane Co. Newbie
    dewey, az
    alright, i adjusted the carb as per earlier directions and it seems to be running pretty smoothlt now. i pulled out #1 & #2 plugs which i just replaced and they were pretty black. i sanded them back clean and put them back in and that seemed to help also. thanks guys, i really appreciate it :)
  10. dillinja666
    haha i though he ment the ridge inside the carb...nice one nook
  11. Shane Co.
    Shane Co. Newbie
    dewey, az
    thanks for clarifying that. i will get a new one asap.
  12. bkcon
    bkcon Newbie
    ive got the same issue.
    20r aisan carb stock...
    i can run the mixture screw all the way in and it still runs the same.
    20-21 inches vacuum and runs rich.
    fuel glass shows fuel at the middle of sight glass.
    getting about 14mpg
    any ideas? brian
  13. bkcon
    bkcon Newbie
    thanks moonsky.
    i will check them both.
    brian
