Short throw
Discussion in 'Engine/Drivetrain' started by Zombie Monarch, Mar 27, 2011.
  1. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    Anyone know of a good short throw shift kit for a 91 22re? This is an area I admittedly have never done much research into so I'm not sure which brands/names are going to be better.
  2. TRUCK ACTION
    LC Engineering
    :cool:
  3. SD YOTA
    x2 on lc engineering.
    once you get one, you will never want to drive a toyota pickup without one. :waytogo:
  4. standardbyker88
    You can also run the shifter arm from celica or corolla with top loading trans. Sticks are generally interchangable. I have a shortened chrome car one in my truck. Love it.
  5. garagedoorman
    garagedoorman Addict
    north georgia
    I'm assuming your referring about a true short shifter. Which narrow the distance that it take to shift from one gear to another. Not necessarily the length of the shifting arm. I paid almost 300. for mine that goes in my supra, but its hand made. When I finally do my W58 swap, I'll have the stock supra shifter which is shorter, but not a short shifter.
  6. minidreaming
    minidreaming Enthusiast
    North Carolina
    83 Long Bed Deluxe
    Not trying to thread jack, but where could I locate one of these for my 83. Could I pull one from a corolla or supra like byker stated? Novice with these dealios...
    zombies, those shifters from LCE look like nice options. I have got several things from them...great to work with
  7. Zombie Monarch
    Springfield, MO
    Yes I was talking about a short throw shifter. I ordered the one from LC engineering. It should be here in 7 to 10 days.
  8. standardbyker88
    Its all in what term of short you mean. By having a shorter arm it does increase leverage and shorten distances. The LC kit still has a long arm although it doesn't move very far. I like the shorter look. Plus, it's just how I like it...cheap lol
  9. garagedoorman
    north georgia
    280. shipped for mkII supra. Mmmmm shifting goodness
  10. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    What are the year ranges for the Celicas and Corollas that are interchangeable?
  11. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    Can anyone help out with this question?
  12. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    almost all that had a "W" series trans or had a 22r engine...
  13. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    Thank you 22R.
  14. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    BTW, is there a how to on doing this swap available?
  15. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Just remove the boot and theres a couple bolts holding it in. Simple swap. Just make sure the ball is the same size, if not might be little to loose or might have to shave it down a bit.
  16. LowLife89
    LowLife89 Member
    inland empire cali
    1989 Toyota pickup
    Watch out for those little washers when you remove the Shifter, they are a b**ch. If you drop them inside the trans!
  17. Zombie Monarch
    Springfield, MO
    Seriously is one of the easiest mods to do. After you take your shift boot off there are 6, 10mm bolts. Undo the 6 bolts, take out the whole arm assembly, take old shift arm out of the shift housing (you just push it down and twist), put the new one in (push and twist the other way), put the spacer then the shift arm assembly back on with the 6 new bolts that came with the kit, VWALA! Short throw installed!
  18. IronNam
    Where would I get one of those!
  19. TRUCK ACTION
    I had to shave the ball down in size to get to work!!!
    And I also told LC!!:cool::cool:
  20. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    How'd yuu shave the ball down?? The short shifter one i got from LC is way bigger too!
