Hid ballast mounting
Discussion in 'Exterior/Body' started by bagged4doorcivic, Apr 12, 2011.
  1. bagged4doorcivic
    bagged4doorcivic Newbie
    I'm having a hard time deciding where I should mount the ballast for the hid's. Does any one have pics showing where you mounted them or just chime in on wheres a good spot to mount them. Thanks
  2. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    behind the headlights so it wont get too wet from rain or wherever you feel comfortable. just don't let it get wet and you'll be fine. grill would also be ok.
  3. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    I put mine in on the fender wells. It works great and they never get exposed to water, this could be a problem if you have no fender wells but thats a whole diff story
  4. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    dont mount it to the grill...you don't wana see it, let alone have it open to damage and weather
    I have mine on the inside fender, not the well but on the side if that makes any sense, i'll get you a pic tomorrow when there is daylight, but one is basically beside the battery the other next to the airfilter
  5. joeynational
    PHX,AZ
    91 2WD
    sorry took a little longer, here is where mine are mounted, my ballasts came with that bracket which made it much easier.
  6. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    i did it the same way as that guy ^^
