79 torsion question
Discussion in 'Suspension/Chassis' started by toyotanator, Apr 7, 2011.
  1. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    I've tried everything to break the bolts loose my question is can i cut the bolts out and replace them so i can lower my truck
  2. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Try heating them up. Might loosen them up.
  3. jetas
    careful when you cut them. its guna shoot out at you
  4. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    Any one know the bolt size
  5. minidreaming
    minidreaming Enthusiast
    North Carolina
    83 Long Bed Deluxe
    On my 83 which is similar i believe they were 17-18mm. I had the same problem with my bolts. I took them to my tire guy and it broke them loose for free. He even said it took him a while and eventually his air socket. I would suggest that option before you cut them out. Much less hassle in the end. Good luck as well
  6. standardbyker88
    PB Blaster overnight and some heat. And try a cheater bar on the end of the wrench. I wouldn't advise cutting them out.
  7. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    Cutting them would be dangerous. Use a penetrating oil and a cheater like said above. They are a pain. If that isn't working, get an impact. Either take it somewhere or rent one.
  8. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    ok ... DO NOTCUT THEM
    THEY HAVE JAM NUTSON THE TOP OF BOLT MAKE SURE THAT YOU BREAK THEM LOSSE FROM EACHOTHER FIRST..
    But as said above try using some heat and then quench them with some water ... but get some new bolts if you go this way..
    and good luck
  9. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    I tried heeating them and the nuts wont move and trried cleaning the treads
  10. mikes87yota
    mikes87yota Enthusiast
    Tacoma Washington
    1983 2WD SR5 "Mojave Edition"
    dude here is a simple way how to do it get a 19mm wrench on the top of the lock nuts spray hella oil then get a breaker bar with a pipe at the end of it and go at dude i this should get it...mine were rusted on shut and i still go it loose lol
  11. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    I finally broke them loose today with two cans of liquid wrench and alot of blood
    i will post some pics some time this week
