Ok Ive got a couple questions about some projects that have been throwing around in my head. Im going to run a set of 18x8 rims +35/+40 offset (cant remember which) in the spring but I want to have as much clearance up front as i can. Currently I do not have 4wd fenders because Im waiting for warmer weather so paint work will be easier. Now my real questions 1. If I run a 245/40/18 in the rear what size should i run up front? I also do not have power steering so the thinner tire i can run the better. 2. Does anybody have a pictured layout of how they did their trailor fenders up front? I want to do this in the summer so i can go lower.
I'm running 235/40's both front and back on 18x8 (+40). They are just about the same height as stock.
read through this build profile....... he runs a similar tire/wheel combo you are. wheels are 18x8 front +38 offset, 18x8.5 rear +35 offset with a 225/40 tire running up front..... http://www.toyotaminis.com/forum/build-up-project-threads-25/lil-red-second-chance-1965/
I have that same wheel and tire combo, 18x8 front and 18x8.5 rear. Im running 225/40/18 in the front and 245/40 in the rear.
