Her Name Is Frank
Discussion in '1976-1983 Build-Up/Project Threads' started by Twisted Minis, Nov 28, 2006.
  1. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    I swapped to 84-88 spindles and balljoints, and modded the lower arms to accept them and made my own uppers. Only way you can get a drop spindle. These things get ridiculous camber with stock spindles. This was stock spindles:
    [​IMG] There was literally NO ROOM for a bag. My upper arm was nearly 90 degrees from the ground. Retarded.
    As far as updates, its at the bodyshop probably not getting worked on much.
  2. 79muttyota
    79muttyota Enthusiast
    Rome, GA
    79 sr5
    Do you have any pics of how you modded the lower c-arms? What mods had to be made?
  3. Twisted Minis
    Poor Cal
    1980 Toyota
    You have to angle the arm before the balljoint, so that it doesnt bind.
    I found the pictures from when I did it.
    Make sure to cut it behind the balljoint mounting holes, and gusset it either inside the arm or outside. I decided it looked better plating it inside the arm.
  4. 79muttyota
    Rome, GA
    79 sr5
    Thanks for the help. That looks too hard for my skill level. :eek:
  5. Twisted Minis
    Poor Cal
    1980 Toyota
    Its pretty easy, just pie cut and bend.
    You can use newer Toyota arms, but it will push your wheels out about 1/2" on each side. And if you want to tuck, that will kill you right there because my tires are about 3/8" away from the fender on the way down.
  6. jf08
    jf08 Newbie
    this truck is so sweet. would you have to create new mounts for the newer toy arms or would it pretty much just bolt up? anymore update?
  7. 79muttyota
    Rome, GA
    79 sr5
    were you able to keep the stock front brakes with the drop spindles or did you have to use 84-88 brakes?
  8. east1la
    east1la Enthusiast
    nc
    1993 toyota pickup dually
    damn, thats a major difference!! keep up the great job!!
  9. east1la
    east1la Enthusiast
    nc
    about how much to have the chassis painted??
  10. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    Very nice build.
    I was just browsing the net looking for other people into the older hilux's then I stumbled on this board and saw this thread :eek:
    Even had to tell my grandma about your truck.
    Seems like the last update you did was about 5mo ago. has it been enuff time for bed install and paint? Feels like I read everything but the last chapter of a great book that was never finished
  11. 79muttyota
    Rome, GA
    79 sr5
    Seth has a street souce profile.http://www.streetsource.com/viewownerprofile.aspx?profileid=38809 It's listed as a 1980 lexus 220 for some wierd reason. The cab is now painted a flat light blue and the bed is still in the works.
  12. Twisted Minis
    Poor Cal
    1980 Toyota
    Sorry I have not been on in a long while. My truck looks much different now.
    Its listed as a Lexus because of the wheels, and the grill emblem. The 220 is for engine size. I am planning on modifying my valve cover to also say Lexus.
  13. Tacomacalistud
    Tacomacalistud Newbie
    orange county
    90 x cab v6
    dude your truck amazes me!!!! my pretaco will be at reso watch for it, where in cali r you?
  14. Twisted Minis
    Poor Cal
    1980 Toyota
    I'm in Windsor. North of San Francisco, south of Redding.
  15. baggedminiz
    baggedminiz Newbie
    Gettysburg, PA
    1986 Toyota Pickup Sport
    so this is the truck i'm madly in love with!!!!! LOL
    saw this beast on SSM.com and went nuts for like a week on it! :D
    Love what you've done, and sorry, i didn't read the other posts, but what size wheels are u running? an i'm guessin you either had an automatic or are puttin one in b/c there's not Clutch Master Cylinder there. Which sucks for me if that's the same size or smaller than what wheels i wanna run.
  16. Twisted Minis
    Poor Cal
    1980 Toyota
    Its got 18" wheels. The wheel tubs come up to the pinch weld on the firewall.
    And its a 5 speed truck. :D
  17. east1la
    east1la Enthusiast
    nc
    thats nice
  18. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    looking great man!
  19. toyotareference
    toyotareference Member
    Portland OR
    01 Tundra
    How about an update on this! I just discovered this thread and read every single page. Looking great... but I'd like to see it fully painted!
  20. phatmitzu
    phatmitzu Veteran
    SoCal 626
    93 Standard Cab 5spd
    Damn.. :eek:
    Thats an awesome Toyo
