Looking for rear Toxic shocks for a 2-3 drop
Discussion in 'Suspension/Chassis' started by stimanmark, Feb 21, 2011.
  1. stimanmark
    stimanmark Member
    North GA/South TN area
    93 reg cab, 22re
    I found the Toxic shocks for the front of my 93 p'up and cant find the Toxics for the rear 3" drop. Help please
  2. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    How is it lowered in the rear end? If its just blocks on stock springs, the shock travel is unchanged.
  3. stimanmark
    stimanmark Member
    93 reg cab, 22re
    Well the factory shocks are blow out and wanting to get some good quality Toxic 2-3 shocks
  4. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    What I am saying is the stock shock travel is still retained if you lowered your rear end with just a set of blocks. So the correct size shock you would need in that case would be a stock shock for a '93 truck. The top shock mount and the bottom shock mount would be exactly as far apart as before lowering as all the blocks do is lift the axle higher.
