302 swap
Discussion in 'Engine/Drivetrain' started by Theory17, Feb 18, 2011.
  1. Theory17
    Theory17 Newbie
    im looking to put a 302 in my 91 toyota in about 6 months...was just wanting to know what all has to be done for the swap...any info will be helpfull
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Engine and trans out of what?
    auto or 5 speed?
    There is room in the engine bay for the motor. Youll need a "dual" or aka rear sump from a fox body.
    The trans (if a 5 speed) uses a cable operated throw out. Easiest way is a MCleod hydralic throw out bearing, but its like 400 bucks. Cheapest is a pull slave mounted on the trans.
    Northwestoffroad has conversion motor mounts. They are 200 bucks and supposibly will work. I called them and they said it hasnt been done yet in a 2wd. (as far as they know).
    The 94-95 mustang, or 96+ explorer use the most compact serpentine setup. IDK about v-belt setups.
    Depending on what trans you have will determine if you have to cut the firewall. Ill tell you that the T5 bellhousing doesnt fit to nicely in my celica, I had to saw-zall the whole area.
  3. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    Then you are going to need to rig a rear end...
  4. Theory17
    Theory17 Newbie
    it's going to be a 302 out of a mustang...prolly going to do carb. 5 speed,gonna try to use the mustang tranny to if i can ....just not sure of what type of rear end to use.
  5. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    im in the process of finishing my 302 swap now i have the motor and tranny mounted i had a buddy make the mounts which are solid no rubber bushings all steel i have a 302 with c4 im going to run the stock rear for now but will upgrade to a 8.8 mustang rear im bagged and bodied and headers won't work on my application and where i have it sitting i had to cut the firewall to move it back. you can look at my thread http://www.toyotaminis.com/forum/build-up-project-threads-25/update-black-widow-2379/
  6. Theory17
    Theory17 Newbie
    how far did you have to move the firewall back?....so it will drop it with out any cutting as long as you dont slam the truck on the ground.
  7. KwoteMan11
    KwoteMan11 Newbie
    Harrisburg Pa
    90xcab
    hello all, if any one gets this can you please responed. i'm new and have made several post but none seem to register. not sure what i need to do different :-(
  8. Theory17
    Theory17 Newbie
    yo man
  9. Dogfather
    Dogfather Veteran
    Rochester, Washington
    Wow Dude sounds Like you've done that a time or two.
  10. thundering02
    thundering02 Addict
    Fenton 63026
  11. Raffaelli
    Houston
    82 Longbed 2WD
    Im in a swap now...
    and thought as much out as I could before hand.
  12. tuckintaco93
    tuckintaco93 Member
    holt , fl
    1993 taco
    yeah i also did a v8 swap but i went with the 307 ...everyone usees the 302,350,305 ... just wanted to be dif. also i made my own mount the ones they sell set the motor back to far for me ..here is a new pics geting it cleaned and preped for the show season
    here is some old pics of it
  13. tuckintaco93
    tuckintaco93 Member
    holt , fl
    1993 taco
  14. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Dang that is sweet. Nice ride man
