Shorty's 94 Project
Discussion in '1989-1995 Build-Up/Project Threads' started by ShortyzKustomz, Feb 13, 2011.
  1. ShortyzKustomz
    ShortyzKustomz Enthusiast
    Central Va.
    94 Single Cab
    Finally decided to do a build thread, Im gonna show what all Ive done over the last 3-4 years and then continue with what Im workin on now. This truck was my only daily driver for 2 years And for the last year and a half its been in my buddies garage... Now theres no garage space and its sitting outside and I have little to no money, Ive been cut off cause of my wedding in a few months and getting in a place etc etc. So projects will be small low budget for a little while :)
    Here it is at Freak Show 3 years ago, This is how I was daily driving it, On the way home from the show, timing chain guide broke and a motor clean up took place
    While the motor was apart I did some more mods while I had downtime, Shaved mirrors and bike mirrors went on
    Motor apart
    Did the valve cover at work
  2. ShortyzKustomz
    Central Va.
    94 Single Cab
    Also cleaned up some interior work while I was at it
    Getting there
    Smoked the tails too
    Back running and cleaned up... Got it back together, Washed and drove it for the first time in 5 months, And headed out the next morning at 7am For Carlisle Truck Nationals... All new wiring, battery in bed, and whole front of the motor replaced.
    Timing chain guides anyone? Metal ones in there now
  3. ShortyzKustomz
    Central Va.
    94 Single Cab
    How the exhaust ran back then
    Semi Horn
    In its new home for a while, My buddies garage
    Inside gutted
    Sadistics Mono Suicide Hinge Setup
    Cut marks for hinge pockets
    Test Fit
  4. ShortyzKustomz
    Central Va.
    94 Single Cab
    Rock Mount Latch Kit, This kit sucks by the way Door flew open on the trailer a few months ago
    Re wiring and plumbing the back of the truck and relocating the fual tank between the rails
    Out with the old bed
  5. ShortyzKustomz
    Central Va.
    94 Single Cab
    Another night done
    Was gonna keep stock handles, but decided what the hell!
    1 done
    Tunnel sealed up
  6. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Nice truck! Now I know what my white truck will look like sittin on the ground. :lol:
  7. ShortyzKustomz
    Central Va.
    94 Single Cab
    Ressurection 2K10 Drag Contest
    New bed, Was a disaster, Bondo filled, But We got it done
    Bracing up, new bed floor
    Tubs in
    Sheeting it up
    Tailgate project begins
    Made my own handle relocator
    Thought I would like 20s... I didnt, This lasted about 2 months haha
    Bed work...ugh
    Starting to look like a truck again
  8. ShortyzKustomz
    Central Va.
    94 Single Cab
    And heres where we are now, Now its on 18s Im hoping to atleast come up with enough money to get the wood bed floor done and get new door latches and get the interior back together so I can drive it again some, Im also trying to redo the back setup to get it to lay on 18s now (It layed fine on 17s) and then I am going to Z the front.
    Did some 8000k HIDs a few weeks ago
    And thats how she sits now...
  9. gslif
    gslif Newbie
    Edmonton, AB, Canada
    91 Yota reg.cab
    still got the old bed??
  10. ShortyzKustomz
    Central Va.
    94 Single Cab
    Yep, been on here for sale a few times, Its FREE to whoever wants it, Not dealing with shipping on a free bed though
  11. ShortyzKustomz
    Central Va.
    94 Single Cab
    Needs a Z some kinda bad
    End of another night
    And this is why it was on the lift, Tranny X member modded
  12. yota4life
    How do you like those suicide door hinges? How far do the open? Any problems with them?
  13. ShortyzKustomz
    Central Va.
    94 Single Cab
    the hinges are great, I'd say they open about 80 degrees, give or take, The door latches were my problem, they have given me issues since day 1. I need to weld in stops to keep them from bumping the body on full open, Kit was alot easier to tweak then regular suicide setups...
  14. yota4life
    I'll have to check into this kit more
  15. lowest93
    lowest93 Enthusiast
    sac town, cali
    93 toyota standard cab
    do you still have the tailgate? and i might be wrong but is the inside of the bed cut up
  16. ShortyzKustomz
    Central Va.
    94 Single Cab
    I traded that gate to "DaRoach" on here for the stock gate I put the lights in now. Yeah inside of the bed was pretty cut out when I got it, Which is why I started on a stock bed, even though alot of my new floor is gone now (under the raised bed floor) I wanted to start fresh. Yet another reason the old one is free for the taking
  17. ShortyzKustomz
    Central Va.
    94 Single Cab
    Some updates, Starting next week the truck comes apart, Starting on a full frame from the firewall back sfbd of course... Pics to follow :)
  18. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Nice progress man its coming along very well. Gotta a question though, are you running drop spindles up front?? On my truck Im thinking If I add drop spindles and remove and raise the tranny cross member I should be able to lay frame in the front without doing a Z. Just a thought on my end so wanted to see what you think.
  19. planemos
    planemos Toyotaholic
    British Columbia
    So I was looking at your picture of the plated transmission crossmember. I was thinking of doing the same. My truck isn't z'd either but it would be better if it was because you could cut out more of the bottom of that crossmember since the transmission mount would get raised. So with that current configuration you can only cut out so much. I was wondering how much of a difference that made. Did it make the frame lay out completely? Or was the transmission crossmember still touching the ground first after you plated the bottom?
  20. yota4life
    Are those niche spitfires? If so u son of a bitch I got the same haha
