no power
Discussion in 'Engine/Drivetrain' started by flyinryanp, Feb 6, 2011.
  1. flyinryanp
    flyinryanp Banned
    north bend o
    79 toyota pickup
    driving down the highway and all of a sudduen truck has no power cant get over 55 mph. no take off power. truck starts fine idles fine is driveable but has no power. any thoughts
  2. planemos
    planemos Toyotaholic
    British Columbia
    is it wet and raining. is there rust. electrical or fusebox problem maybe
  3. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Check the basics oil, gas, spark, it happened to a buddy of mine he was about two qts low and was running on fumes :/
  4. flyinryanp
    flyinryanp Banned
    north bend o
    79 toyota pickup
    checked all the basics plugs wires fluids no it wasnt raining and there are no codes. it runs fine just has a serious lack of power. all of a sudden i was thinking maf, coolant temp sensor, or o2 sensor.
  5. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    Fuel Filter? Just a stab in the dark.
  6. 4norzn
    4norzn Newbie
    dont these have throttle position sensors?
  7. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Fuel filter is PLUGGED up.
    Water in the gas.
    Kinked exhaust
    Or a plugged up cat.
    Im guessing cat. Unbolt the exhaust in front of the cat and drive it.
  8. IronNam
    Yes they do.
    hmm....... timing?
    EFnetOper, put that knife away! :lol:
  9. planemos
    British Columbia
    flyinryanp you live in Bend Oregon? That's kinda funny cuz my dad and I had a turbo diesel 22re 4x4 with a camper and it broke down there once lol. We left it in a yard and rented a car and drove home to Canada lol :D
    Maybe it's the geography?
  10. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    +1 for clogged cat...
    I didnt know 79's were EFI??? Might help to know what engine you have...
  11. flyinryanp
    flyinryanp Banned
    north bend o
    79 toyota pickup
    i was possibly thinking clogged cat too. i live in north bend not bend different place. i would think timing but it did while driving nothing changed and it starts and idles fine. when you take off it seriously lacks power as you get to about 3000 rpms a picks up a bit. im just trying to see what commonly goes wrong with these trucks oh and just to be clear it is a 92 2wd 22re
  12. dillinja666
    There are so many things that could cause this that i would bring it to a shop to have them figure out whats wrong, after they figure it out come back on here and we can walk you through how to fix it. Everything from a jumped timing chain, clogged cat, clogged fuel filter, secondary ignition break-up, blah blah blah would cause this. If i was there and could listen to your truck it would be a simple fix, but instead of having you possibly wasting your money on cats and what not how about you have a shop look at it and come back with the results....
    just my 2 cents
