I just bought a car with a 20r engine and no head or intake manifold or carb. It seems like someone took it apart to do a valve job and it got separated. I do have the rocker assemble. Any help in getting the parts to get the engine up and running is greatly appreciated. I live in massachusetts.. Again, Thanks Bill
Here's some stuff that may help you out... I have a used head that needs to be cleaned up and the #4 spark plug hole re-threaded. Might need 1 or 2 exhaust studs also re-threaded aswell... Block mating surface is a 10, no corrosion... I'd still have it re-surfaced tho. I have to double check if it has fuel pump and power steering bosses... I also have the intake manifold that I had cleaned up for a holley carb. I dont have a 20R carb only a stock 22R carb, which can work if you get the adapter from LC engineering... $50 for the head (stock cam and steel rockers included). You pay shipping, which will be around 25-35 bucks UPS ground... $40 for the intake + shipping $85 for the 22R carb + shipping Let me know...
Hi, thanks a lot . I bought what i needed from Javiar. HeHis parts didn;t need any work to get my engine going. Thanks again, Bill
